stock exhaust manifolds on a 67 Coronet #3020768
03/04/22 12:26 PM
03/04/22 12:26 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Can I use the 68-70 HIPO exhaust manifolds on a 67 Coronet with a 440?
Im not concerned with dead nuts correct. As I will have head pipes made up locally
Re: stock exhaust manifolds on a 67 Coronet [Re: gtx6970] #3020802
03/04/22 01:48 PM
03/04/22 01:48 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I don't see a problem; front structure & layout is pretty much the same.
I can't recall what my stock/original '67 GTX had for exhaust manifolds, but I think they were the '68-'70 HP style.
I googled it and they look the same.
Clocking of the head pipe flanges is different on '70 than '68-'69, neither should be a problem.
Re: stock exhaust manifolds on a 67 Coronet [Re: topside] #3020831
03/04/22 03:44 PM
03/04/22 03:44 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Thanks, Thats kind of what I thought , I know the mounting is different between 67 versus 68-70 . and I know the head pipe attachment is clocked different for 1970.
But dont care either way.
Car I bought has headers which will go away as soon as I can find some manifolds reasonably priced .
Im planning to have head pipes made locally
Re: stock exhaust manifolds on a 67 Coronet [Re: gtx6970] #3020843
03/04/22 04:27 PM
03/04/22 04:27 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Just make sure you get HiPo manifolds for B Body . . . C Body right is same, but left (drivers side) is different shape to fit around the steering column on C body and interferes if used on B body . . .
Re: stock exhaust manifolds on a 67 Coronet [Re: a12rag] #3020851
03/04/22 05:11 PM
03/04/22 05:11 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Re: stock exhaust manifolds on a 67 Coronet [Re: gtx6970] #3020892
03/04/22 07:56 PM
03/04/22 07:56 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Probably don't need to tell you, but will anyway:
Make sure the flanges are flat & true before you bolt 'em on.
Blanchard grinder or a long belt sander & a sense of feel can correct them.
Used to be Walker had the exhaust system for a lot less than the resto guys, if you want the stock pipes.
Re: stock exhaust manifolds on a 67 Coronet [Re: topside] #3020947
03/04/22 11:27 PM
03/04/22 11:27 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Plan to insure they are flat.
A friend of a friend of mine owns an exhaust shop locally.
Planning to have him bend up new head pipes. and maybe even do away with the flowmasters . I pick the car up next week. and once I see how loud it is, or not. Then will decide on mufflers or not
Re: stock exhaust manifolds on a 67 Coronet [Re: gtx6970] #3021005
03/05/22 10:58 AM
03/05/22 10:58 AM
JERSEY
RJS Offline
RJS  Offline
JERSEY
I come from the other side of this, why take off working headers???? If they have a flange leak put Rem Flex gaskets on and problem solved.
To give away 30-50 horsepower for no good reason I rather kiss AOC!!
Ron
Re: stock exhaust manifolds on a 67 Coronet [Re: RJS] #3021382
03/06/22 09:58 PM
03/06/22 09:58 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Ron
Ron, this car is more a crusier than a hot rod.
I would rather not deal with leaks, burnt plug wires etc etc
Plus, I mainly hate the look
Re: stock exhaust manifolds on a 67 Coronet [Re: gtx6970] #3021499
03/07/22 01:05 PM
03/07/22 01:05 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Ha Ha you're just afraid of horsepower!!
Ron
Re: stock exhaust manifolds on a 67 Coronet [Re: RJS] #3024428
03/15/22 10:57 PM
03/15/22 10:57 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Maybe time for a nitrous kit?
Re: stock exhaust manifolds on a 67 Coronet [Re: gtx6970] #3024471
03/16/22 08:54 AM
03/16/22 08:54 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Ron
iagree
