Re: stock exhaust manifolds on a 67 Coronet
[Re: topside]
#3020831
03/04/22 03:44 PM
03/04/22 03:44 PM
Posts: 21,428 It's a dry heat
gtx6970
It's a dry heat
I don't see a problem; front structure & layout is pretty much the same. I can't recall what my stock/original '67 GTX had for exhaust manifolds, but I think they were the '68-'70 HP style. I googled it and they look the same. Clocking of the head pipe flanges is different on '70 than '68-'69, neither should be a problem. Thanks, Thats kind of what I thought , I know the mounting is different between 67 versus 68-70 . and I know the head pipe attachment is clocked different for 1970. But dont care either way. Car I bought has headers which will go away as soon as I can find some manifolds reasonably priced . Im planning to have head pipes made locally
[Re: topside]
#3020947
03/04/22 11:27 PM
03/04/22 11:27 PM
gtx6970
It's a dry heat
Probably don't need to tell you, but will anyway: Make sure the flanges are flat & true before you bolt 'em on. Blanchard grinder or a long belt sander & a sense of feel can correct them. Used to be Walker had the exhaust system for a lot less than the resto guys, if you want the stock pipes. Plan to insure they are flat. A friend of a friend of mine owns an exhaust shop locally. Planning to have him bend up new head pipes. and maybe even do away with the flowmasters . I pick the car up next week. and once I see how loud it is, or not. Then will decide on mufflers or not
[Re: RJS]
#3021382
03/06/22 09:58 PM
03/06/22 09:58 PM
gtx6970
It's a dry heat
I come from the other side of this, why take off working headers???? If they have a flange leak put Rem Flex gaskets on and problem solved. To give away 30-50 horsepower for no good reason I rather kiss AOC!! Ron Ron, this car is more a crusier than a hot rod. I would rather not deal with leaks, burnt plug wires etc etc Plus, I mainly hate the look
[Re: gtx6970]
#3024471
03/16/22 08:54 AM
03/16/22 08:54 AM
Posts: 10,714 North Dakota
6PakBee
North Dakota
