Probably don't need to tell you, but will anyway:
Make sure the flanges are flat & true before you bolt 'em on.
Blanchard grinder or a long belt sander & a sense of feel can correct them.
Used to be Walker had the exhaust system for a lot less than the resto guys, if you want the stock pipes.
