oil pans #2853356
11/30/20 02:15 PM
11/30/20 02:15 PM
ohio
dbran451 Offline OP
dbran451  Offline OP
ohio
was wondering what oil pans you are using for added ground clearance, we have a 71 duster with a tubular front suspension and a rack but only have 2.5 inches of ground clearance thanks for any info
Re: oil pans [Re: dbran451] #2853394
11/30/20 03:12 PM
11/30/20 03:12 PM
AndyF Offline
AndyF  Offline
How much room between the oil pan rail and the ground?
Re: oil pans [Re: AndyF] #2853397
11/30/20 03:22 PM
11/30/20 03:22 PM
Odessa, Fl
blowndart Online content
blowndart  Online Content
Odessa, Fl
BB, SB, gen III Hemi?
Re: oil pans [Re: AndyF] #2853406
11/30/20 03:41 PM
11/30/20 03:41 PM
ohio
dbran451 Offline OP
dbran451  Offline OP
ohio
about 2.5 inches moroso pan with a static pickup
Re: oil pans [Re: blowndart] #2853409
11/30/20 03:42 PM
11/30/20 03:42 PM
ohio
dbran451 Offline OP
dbran451  Offline OP
ohio
big block
Re: oil pans [Re: dbran451] #2853413
11/30/20 03:46 PM
11/30/20 03:46 PM
I used the stock Mopar 1970/71 440 6 pack and street hemi pan in my old pump gas 1971 Duster with the motor moved back a little to clear the stock K frame, 6 quarts and not very deep up That car ran 10.00 with one 9.993 ET at 134.+ MPH in the 1/4 mile and never had a oiling issue as long as I kept the oil level above the add mark up
Lots of runs and lots of street miles boogie
Re: oil pans [Re: dbran451] #2853418
11/30/20 03:48 PM
11/30/20 03:48 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
Been there, done that!!! A few years ago when I installed Lamb struts and R&P steering in my car I thought I had everything blocked up to exactly where I wanted it. I also bought a deepened truck pan for the rear sump. When I got it all installed and the engine installed I had very little clearance between the pan and the floor. I had to do 2 things to get slightly above 3" clearance. I had to raise my engine and I had to section a slice out of the pan. I was using Andy's engine plate so I built my mounts so the plate rested above the frame rail. I redid the pan and extended the sump forward so that it holds the same amount of oil but it is not as deep. The result is I barely have 3" of clearance. I also installed a front air dam on the car and I barely have 3" of clearance for it also. The car sits nice and low in the front but to get the rear as low as I would like for it to be I would have to redo the wheel wells because I currently just barely have clearance between the tire and the top of the tubs.
Re: oil pans [Re: dbran451] #2853447
11/30/20 04:42 PM
11/30/20 04:42 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Do your bump stops make hard contact before the "bang" noise? They can be tuned to act more progressively (not as suddenly) by weakening them: drill holes, taper away the top with a linoleum knife, etc.
Boffin Emeritus
Re: oil pans [Re: dbran451] #2853451
11/30/20 04:47 PM
11/30/20 04:47 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Been using Billet Fabrication....one of the best out there.
http://www.billetfab.com/
Re: oil pans [Re: Dragula] #2853458
11/30/20 05:14 PM
11/30/20 05:14 PM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
Milidon. My Transmission and exhaust sit lower than the oil pan. A lot nicer than the old Moroso I used to run.
https://www.summitracing.com/parts/mil-31581
[Linked Image]IMG_3149 by Greg Ault, on Flickr
Re: oil pans [Re: polyspheric] #2853463
11/30/20 05:20 PM
11/30/20 05:20 PM
ohio
dbran451 Offline OP
dbran451  Offline OP
ohio
There aren't any bump stops
Re: oil pans [Re: dbran451] #2853491
11/30/20 06:20 PM
11/30/20 06:20 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Then watch out for wheelstands eek The pan on the left, where the tape is, is how high it should be blush
Re: oil pans [Re: Dragula] #2853525
11/30/20 07:51 PM
11/30/20 07:51 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
I hope so, I have had one ordered since early July. Was told 5-6 weeks. Followed up after 7wks and was told 5-6 wks. Called in October was told the beginning of November. Still nothing. He said he pulls CC funds before shipping so hope to have it soon as the charge showed on my CC last wk. Glad I didn't really need it in August like promised.
Ok
Re: oil pans [Re: gsmopar] #2853542
11/30/20 08:26 PM
11/30/20 08:26 PM
A727Tflite Offline
A727Tflite  Offline
Is that the Milodon road race pan with trap doors?
Re: oil pans [Re: A727Tflite] #2853555
11/30/20 08:41 PM
11/30/20 08:41 PM
Odessa, Fl
Odessa, Fl
It looks like it. Same one I have on my hemi. Great pan that gives a lot of clearance.
Re: oil pans [Re: A727Tflite] #2853608
11/30/20 11:06 PM
11/30/20 11:06 PM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
Yup! I put the link at the top of the post. No pick up for me! smile
Re: oil pans [Re: gsmopar] #2853687
12/01/20 09:06 AM
12/01/20 09:06 AM
an8sec70cuda Offline
I use the fab'd aluminum 440 source pan on my hemi. Works great.
CHIP
'06 GMC 2500HD LBZ Duramax
