Re: oil pans
[Re: dbran451]
#2853413
11/30/20 03:46 PM
11/30/20 03:46 PM
Posts: 43,157 Bend,OR USA
Cab_Burge
I used the stock Mopar 1970/71 440 6 pack and street hemi pan in my old pump gas 1971 Duster with the motor moved back a little to clear the stock K frame, 6 quarts and not very deep That car ran 10.00 with one 9.993 ET at 134.+ MPH in the 1/4 mile and never had a oiling issue as long as I kept the oil level above the add mark Lots of runs and lots of street miles
Re: oil pans
[Re: dbran451]
#2853447
11/30/20 04:42 PM
11/30/20 04:42 PM
Posts: 4,206 New York
polyspheric
New York
Do your bump stops make hard contact before the "bang" noise? They can be tuned to act more progressively (not as suddenly) by weakening them: drill holes, taper away the top with a linoleum knife, etc.
Boffin Emeritus
Re: oil pans
[Re: polyspheric]
#2853463
11/30/20 05:20 PM
11/30/20 05:20 PM
Posts: 654 ohio
dbran451
ohio
Do your bump stops make hard contact before the "bang" noise? They can be tuned to act more progressively (not as suddenly) by weakening them: drill holes, taper away the top with a linoleum knife, etc. There aren't any bump stops
Re: oil pans
[Re: dbran451]
#2853491
11/30/20 06:20 PM
11/30/20 06:20 PM
Posts: 2,915 A shed in England
Tig
A shed in England
Do your bump stops make hard contact before the "bang" noise? They can be tuned to act more progressively (not as suddenly) by weakening them: drill holes, taper away the top with a linoleum knife, etc. There aren't any bump stops Then watch out for wheelstands The pan on the left, where the tape is, is how high it should be
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
Re: oil pans
[Re: Dragula]
#2853525
11/30/20 07:51 PM
11/30/20 07:51 PM
Posts: 1,099 Massillon, Ohio
cudatom
Massillon, Ohio
I hope so, I have had one ordered since early July. Was told 5-6 weeks. Followed up after 7wks and was told 5-6 wks. Called in October was told the beginning of November. Still nothing. He said he pulls CC funds before shipping so hope to have it soon as the charge showed on my CC last wk. Glad I didn't really need it in August like promised.
Ok
Re: oil pans
[Re: A727Tflite]
#2853555
11/30/20 08:41 PM
11/30/20 08:41 PM
Posts: 965 Odessa, Fl
blowndart
Odessa, Fl
Is that the Milodon road race pan with trap doors? It looks like it. Same one I have on my hemi. Great pan that gives a lot of clearance.
Re: oil pans
[Re: gsmopar]
#2853687
12/01/20 09:06 AM
12/01/20 09:06 AM
Posts: 13,360 Marion, South Carolina [><]
an8sec70cuda
I use the fab'd aluminum 440 source pan on my hemi. Works great.
