Re: Now Powervalve Provisions! AAAHHHHHHHHHHHHH!!!!!
[Re: AndyF]
#284744
04/11/09 03:28 PM
04/11/09 03:28 PM
Posts: 616 Dunedin, Fl
DRDart
mopar addict
mopar addict
Dunedin, Fl
What is the list # on the carb???
[image]http://i682.photobucket.com/albums/vv183/DrDart500/DSC00307.jpg
1966 Charger
1970 Dart 16-1,solid roller,500 ci Tunnel Ram 8" Ati conv,BTE glide, Fab 9 rear strange center sect. Twin Rons terminators on Alky.
[Re: DRDart]
#284745
04/11/09 03:32 PM
04/11/09 03:32 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
didnt Biggs do your carb? did he know it was for a steert car?
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#284746
04/11/09 03:40 PM
04/11/09 03:40 PM
Posts: 3,695 nc
emarine01
nc
Edit
[Re: moparniac]
#284749
04/11/09 04:08 PM
04/11/09 04:08 PM
Posts: 52,972 Romeo MI
MR_P_BODY
yes and the list numbers are milled off..
Its a 1050 dom ... right? Does it have 3 bleeds(holes in the air horn near the vent tube) or 2 air bleeds, (2 or 3 on each side of the vent) do they screw in?
[Re: MR_P_BODY]
#284750
04/11/09 04:23 PM
04/11/09 04:23 PM
Posts: 6,295 U.S.
moparniac
U.S.
its a dominator and 3 on each side... yes they are screw in.... they have a notch for a flathead..
Mopar Performance
[Re: moparniac]
#284755
04/11/09 07:45 PM
04/11/09 07:45 PM
sixpackgut
Charleston
it being a 3 circuit has nothing to do with there being no PVCR.
this is an easy fix, if you have a drill press and a extra metering block with PVCR drilled, setup the drill press so you drill at the right angle and depth. then all you need to do is figure out what size you want the PVCR to be. done
some doms just are not drilled for a PV but with that being said, if the carb was to be built for a street car, it should have them
[Re: sixpackgut]
#284756
04/11/09 08:12 PM
04/11/09 08:12 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
I have a used set of 3 circuit 8896 metering block, that I have from a older project, I upgraded to some Quickfuel billet peices for all out adjustmment. PM me if your interested.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: sixpackgut]
#284758
04/11/09 08:29 PM
04/11/09 08:29 PM
Quicktree
thought the 8896 was 2 circuit
new ones are 3, mine is 3.
[Re: Bob_Coomer]
#284760
04/11/09 09:09 PM
04/11/09 09:09 PM
sixpackgut
Charleston
Way more to it than that, the PV hole is concave shape and provides a well for the PV operations. It would be hard to do this with out a all out machine shop, it would be real easy to mess them up. I would say without the required tooling it would be near impossible to do this.
not
[Re: sixpackgut]
#284761
04/11/09 09:12 PM
04/11/09 09:12 PM
MR_P_BODY
My 8896 is 3
[Re: emarine01]
#284764
04/11/09 09:39 PM
04/11/09 09:39 PM
MR_P_BODY
Hmmm, and why does he want a pv?
They really do help part throttle and tip in for the street
[Re: DRDart]
#284765
04/11/09 09:43 PM
04/11/09 09:43 PM
sixpackgut
Charleston
My 8896 is 3
Mine too!
my mistake, 8082 i was just workin on, i think
[Re: MR_P_BODY]
#284766
04/11/09 09:57 PM
04/11/09 09:57 PM
Posts: 3,695 nc
emarine01
nc
How much gear and verter in that beast , is a pv realy gona make that much difference , 500 inches 700 ponies dont sound like a grocery getter to me
[Re: emarine01]
#284769
04/12/09 10:17 AM
04/12/09 10:17 AM
Posts: 13,380 Marion, South Carolina [><]
an8sec70cuda
I've tried both. YES, a PV does make that much difference on the street. MUCH cleaner at part throttle, your spark plugs will thank you.
Was the carb set up forn the street originally? I do not know why they'd set that carb up for the street without power valves. The one on my hemi has a PV up front. I use Pro Systems and have been extremely happy w/ both of the dominators I've gotten from them. And Patrick is a GREAT guy to deal with. CHIP
