Now Powervalve Provisions! AAAHHHHHHHHHHHHH!!!!! #284740
04/11/09 02:32 PM
04/11/09 02:32 PM
U.S.
moparniac Offline OP
U.S.
So where and how big do I drill... man I cant catch a break...
Mopar Performance
Re: Now Powervalve Provisions! AAAHHHHHHHHHHHHH!!!!! [Re: moparniac] #284741
04/11/09 03:01 PM
04/11/09 03:01 PM
U.S.
U.S.
Mopar Performance
Re: Now Powervalve Provisions! AAAHHHHHHHHHHHHH!!!!! [Re: moparniac] #284742
04/11/09 03:26 PM
04/11/09 03:26 PM
AndyF Online content
AndyF  Online Content
Probably just need to buy new metering plates. You might be able to send those plates to someone like BLP and get them to modify them but new plates is probably the easier way to go. The drill operation is a little tricky since they are at an compound angle plus they need to be tapped for the restriction jets.
Re: Now Powervalve Provisions! AAAHHHHHHHHHHHHH!!!!! [Re: moparniac] #284743
04/11/09 03:27 PM
04/11/09 03:27 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont know the thread diamention is but you might
be better to get a metering block
Re: Now Powervalve Provisions! AAAHHHHHHHHHHHHH!!!!! [Re: AndyF] #284744
04/11/09 03:28 PM
04/11/09 03:28 PM
Dunedin, Fl
DRDart Offline
mopar addict
DRDart  Offline
mopar addict
Dunedin, Fl
What is the list # on the carb???
[image]http://i682.photobucket.com/albums/vv183/DrDart500/DSC00307.jpg 1966 Charger 1970 Dart 16-1,solid roller,500 ci Tunnel Ram 8" Ati conv,BTE glide, Fab 9 rear strange center sect. Twin Rons terminators on Alky.
Re: Now Powervalve Provisions! AAAHHHHHHHHHHHHH!!!!! [Re: DRDart] #284745
04/11/09 03:32 PM
04/11/09 03:32 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
didnt Biggs do your carb? did he know it was for a steert car?
Re: Now Powervalve Provisions! AAAHHHHHHHHHHHHH!!!!! [Re: sixpackgut] #284746
04/11/09 03:40 PM
04/11/09 03:40 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Edit
Re: Now Powervalve Provisions! AAAHHHHHHHHHHHHH!!!!! [Re: emarine01] #284747
04/11/09 04:03 PM
04/11/09 04:03 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Call ProMax
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: Now Powervalve Provisions! AAAHHHHHHHHHHHHH!!!!! [Re: sixpackgut] #284748
04/11/09 04:04 PM
04/11/09 04:04 PM
U.S.
U.S.
yes and the list numbers are milled off.. I just put it back together.... screw it
Mopar Performance
Re: Now Powervalve Provisions! AAAHHHHHHHHHHHHH!!!!! [Re: moparniac] #284749
04/11/09 04:08 PM
04/11/09 04:08 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Its a 1050 dom ... right? Does it have 3 bleeds(holes
in the air horn near the vent tube) or 2 air bleeds,
(2 or 3 on each side of the vent)
do they screw in?
Re: Now Powervalve Provisions! AAAHHHHHHHHHHHHH!!!!! [Re: MR_P_BODY] #284750
04/11/09 04:23 PM
04/11/09 04:23 PM
U.S.
U.S.
its a dominator and 3 on each side... yes they are screw in.... they have a notch for a flathead..
Mopar Performance
Re: Now Powervalve Provisions! AAAHHHHHHHHHHHHH!!!!! [Re: emarine01] #284751
04/11/09 04:27 PM
04/11/09 04:27 PM
UK
602heavy Offline
602heavy  Offline
UK
Fuel exits into the main well , the channel restrictors are no more than 'holes' drilled through the metering block , no restrictors/jets in there to worry about , although you could drill & tap the channel restrictors for some aftermarket screw in restrictors , this would aid in fine tuning the PV circuit , even better you could fit some aftermarket blocks that will have all the removable bleeds/jets to get the job done.
Plug the PV & jet for a tad under 15:1 , reinstall PV & adjust channel restrictors for around 12:1 full throttle.
Re: Now Powervalve Provisions! AAAHHHHHHHHHHHHH!!!!! [Re: MR_P_BODY] #284752
04/11/09 06:06 PM
04/11/09 06:06 PM
U.S.
U.S.
do they screw in?
3 on each side... Dont know why there wouldnt be any holes for the PV like gut stated..
Mopar Performance
Re: Now Powervalve Provisions! AAAHHHHHHHHHHHHH!!!!! [Re: moparniac] #284753
04/11/09 06:13 PM
04/11/09 06:13 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Since its a Bigs carb call Jesse and have him send one
for your carb... he should know what you have
Re: Now Powervalve Provisions! AAAHHHHHHHHHHHHH!!!!! [Re: MR_P_BODY] #284754
04/11/09 06:22 PM
04/11/09 06:22 PM
U.S.
U.S.
Ill send a PM... anyone wanna buy a metering block
Mopar Performance
Re: Now Powervalve Provisions! AAAHHHHHHHHHHHHH!!!!! [Re: moparniac] #284755
04/11/09 07:45 PM
04/11/09 07:45 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
it being a 3 circuit has nothing to do with there being no PVCR.
this is an easy fix, if you have a drill press and a extra metering block with PVCR drilled, setup the drill press so you drill at the right angle and depth. then all you need to do is figure out what size you want the PVCR to be. done
some doms just are not drilled for a PV but with that being said, if the carb was to be built for a street car, it should have them
Re: Now Powervalve Provisions! AAAHHHHHHHHHHHHH!!!!! [Re: sixpackgut] #284756
04/11/09 08:12 PM
04/11/09 08:12 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
I have a used set of 3 circuit 8896 metering block, that I have from a older project, I upgraded to some Quickfuel billet peices for all out adjustmment. PM me if your interested.
Re: Now Powervalve Provisions! AAAHHHHHHHHHHHHH!!!!! [Re: Bob_Coomer] #284757
04/11/09 08:24 PM
04/11/09 08:24 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
thought the 8896 was 2 circuit
Re: Now Powervalve Provisions! AAAHHHHHHHHHHHHH!!!!! [Re: sixpackgut] #284758
04/11/09 08:29 PM
04/11/09 08:29 PM
Q
Quicktree Offline
Quicktree  Offline
Q
new ones are 3, mine is 3.
Re: Now Powervalve Provisions! AAAHHHHHHHHHHHHH!!!!! [Re: sixpackgut] #284759
04/11/09 08:38 PM
04/11/09 08:38 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Way more to it than that, the PV hole is concave shape and provides a well for the PV operations. It would be hard to do this with out a all out machine shop, it would be real easy to mess them up. I would say without the required tooling it would be near impossible to do this.
