Re: Now Powervalve Provisions! AAAHHHHHHHHHHHHH!!!!!
[Re: Bob_Coomer]
#284760
04/11/09 09:09 PM
04/11/09 09:09 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
it being a 3 circuit has nothing to do with there being no PVCR.
this is an easy fix, if you have a drill press and a extra metering block with PVCR drilled, setup the drill press so you drill at the right angle and depth. then all you need to do is figure out what size you want the PVCR to be. done
some doms just are not drilled for a PV but with that being said, if the carb was to be built for a street car, it should have them
Way more to it than that, the PV hole is concave shape and provides a well for the PV operations. It would be hard to do this with out a all out machine shop, it would be real easy to mess them up. I would say without the required tooling it would be near impossible to do this.
not
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#284761
04/11/09 09:12 PM
04/11/09 09:12 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I have a used set of 3 circuit 8896 metering block, that I have from a older project, I upgraded to some Quickfuel billet peices for all out adjustmment. PM me if your interested.
thought the 8896 was 2 circuit
My 8896 is 3
[Re: emarine01]
#284764
04/11/09 09:39 PM
04/11/09 09:39 PM
MR_P_BODY
Hmmm, and why does he want a pv?
They really do help part throttle and tip in for the street
[Re: DRDart]
#284765
04/11/09 09:43 PM
04/11/09 09:43 PM
sixpackgut
Charleston
My 8896 is 3
Mine too!
my mistake, 8082 i was just workin on, i think
[Re: MR_P_BODY]
#284766
04/11/09 09:57 PM
04/11/09 09:57 PM
Posts: 3,695 nc
emarine01
nc
How much gear and verter in that beast , is a pv realy gona make that much difference , 500 inches 700 ponies dont sound like a grocery getter to me
[Re: emarine01]
#284769
04/12/09 10:17 AM
04/12/09 10:17 AM
Posts: 13,387 Marion, South Carolina [><]
an8sec70cuda
I've tried both. YES, a PV does make that much difference on the street. MUCH cleaner at part throttle, your spark plugs will thank you.
Was the carb set up forn the street originally? I do not know why they'd set that carb up for the street without power valves. The one on my hemi has a PV up front. I use Pro Systems and have been extremely happy w/ both of the dominators I've gotten from them. And Patrick is a GREAT guy to deal with. CHIP
