Re: Now Powervalve Provisions! AAAHHHHHHHHHHHHH!!!!! [Re: Bob_Coomer] #284760
04/11/09 09:09 PM
04/11/09 09:09 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
it being a 3 circuit has nothing to do with there being no PVCR.
this is an easy fix, if you have a drill press and a extra metering block with PVCR drilled, setup the drill press so you drill at the right angle and depth. then all you need to do is figure out what size you want the PVCR to be. done
some doms just are not drilled for a PV but with that being said, if the carb was to be built for a street car, it should have them
Way more to it than that, the PV hole is concave shape and provides a well for the PV operations. It would be hard to do this with out a all out machine shop, it would be real easy to mess them up. I would say without the required tooling it would be near impossible to do this.
not
Re: Now Powervalve Provisions! AAAHHHHHHHHHHHHH!!!!! [Re: sixpackgut] #284761
04/11/09 09:12 PM
04/11/09 09:12 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I have a used set of 3 circuit 8896 metering block, that I have from a older project, I upgraded to some Quickfuel billet peices for all out adjustmment. PM me if your interested.
thought the 8896 was 2 circuit
My 8896 is 3
Re: Now Powervalve Provisions! AAAHHHHHHHHHHHHH!!!!! [Re: MR_P_BODY] #284762
04/11/09 09:18 PM
04/11/09 09:18 PM
Dunedin, Fl
DRDart Offline
mopar addict
DRDart  Offline
mopar addict
Dunedin, Fl
My 8896 is 3
Mine too!
[image]http://i682.photobucket.com/albums/vv183/DrDart500/DSC00307.jpg 1966 Charger 1970 Dart 16-1,solid roller,500 ci Tunnel Ram 8" Ati conv,BTE glide, Fab 9 rear strange center sect. Twin Rons terminators on Alky.
Re: Now Powervalve Provisions! AAAHHHHHHHHHHHHH!!!!! [Re: DRDart] #284763
04/11/09 09:29 PM
04/11/09 09:29 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Hmmm, and why does he want a pv?
Re: Now Powervalve Provisions! AAAHHHHHHHHHHHHH!!!!! [Re: emarine01] #284764
04/11/09 09:39 PM
04/11/09 09:39 PM
MR_P_BODY Offline
MR_P_BODY  Offline
They really do help part throttle and tip in for the
street
Re: Now Powervalve Provisions! AAAHHHHHHHHHHHHH!!!!! [Re: DRDart] #284765
04/11/09 09:43 PM
04/11/09 09:43 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
My 8896 is 3
Mine too!
my mistake, 8082 i was just workin on, i think
Re: Now Powervalve Provisions! AAAHHHHHHHHHHHHH!!!!! [Re: MR_P_BODY] #284766
04/11/09 09:57 PM
04/11/09 09:57 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
street
How much gear and verter in that beast , is a pv realy gona make that much difference , 500 inches 700 ponies dont sound like a grocery getter to me
Re: Now Powervalve Provisions! AAAHHHHHHHHHHHHH!!!!! [Re: emarine01] #284767
04/11/09 10:17 PM
04/11/09 10:17 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Here is those metering blocks we was discussing through PM Wedge-o-.. I dont know what the NON power valve provisioned metering blocks look like, but im sticking to my guns saying that it would be hard to add this...Unless that part is already machined, but still finding that odd ball tap, will be both expensive and hard enough....A option might be to send your current ones off to maybe have them converted.... You can see the concave area I was speaking of clearly..
Re: Now Powervalve Provisions! AAAHHHHHHHHHHHHH!!!!! [Re: Bob_Coomer] #284768
04/12/09 09:44 AM
04/12/09 09:44 AM
U.S.
moparniac Offline OP
U.S.
pm sent
my metering block dont have the holes in the side like that either..
Mopar Performance
Re: Now Powervalve Provisions! AAAHHHHHHHHHHHHH!!!!! [Re: emarine01] #284769
04/12/09 10:17 AM
04/12/09 10:17 AM
an8sec70cuda Offline
street
I've tried both. YES, a PV does make that much difference on the street. MUCH cleaner at part throttle, your spark plugs will thank you.
Was the carb set up forn the street originally? I do not know why they'd set that carb up for the street without power valves. The one on my hemi has a PV up front.
I use Pro Systems and have been extremely happy w/ both of the dominators I've gotten from them. And Patrick is a GREAT guy to deal with. CHIP
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Now Powervalve Provisions! AAAHHHHHHHHHHHHH!!!!! [Re: an8sec70cuda] #284770
04/12/09 10:35 AM
04/12/09 10:35 AM
UK
602heavy Offline
602heavy  Offline
UK
Hey Wedge , if you have to replace the blocks then it's only gonna be the front one , no big deal , why sell it.
Re: Now Powervalve Provisions! AAAHHHHHHHHHHHHH!!!!! [Re: 602heavy] #284771
04/12/09 11:03 AM
04/12/09 11:03 AM
Mopar Lane,Mississippi
67HEMI Offline
67HEMI  Offline
Man after reading all of these threads on carburetors I am amazed that my 9375 stock out of the box plus jet extensions works No powervalves,no billet metering plates,no fancy throttle plates. Wedge just buy a new Holley,put jet extensions on it,set your base timing on 18 and jet it for your air.
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction) '69 Chrysler 300 Convertible 375 HP 440 '71 Plymouth Duster 360 W/EFI (Wife's Ride) '12 Ram MegaCab Dually 6.7 Cummins
