Re: cleaning under-hood wiring?
[Re: sharpie]
#275413
04/02/09 08:27 PM
04/02/09 08:27 PM
Posts: 2,356 Kentucky
dfsmopars
Kentucky
I take plenty of pictures. I make sure I have a wiring diagram and then I go to unwrapping the "tape". Everything under the wrap should be clean. What is not clean I use mineral spirits to remove the grease and then wash it all in soapy water. After everything is clean and inspected I wrap it back the way I found it. It is not as big a job as it appears at first.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring ‘14 Big Horn, Quad Cab, 4x4, 1500
[Re: In_The_Pink]
#275415
04/02/09 09:18 PM
04/02/09 09:18 PM
Posts: 412 Cleveland,Ohio
CtownChris
Cleveland,Ohio
Wipe heavy grim off with rag and degrease (simple green) then top rack of dish washer.
"Always go forward: Never go straight"
[Re: sharpie]
#275419
04/03/09 03:20 PM
04/03/09 03:20 PM
Posts: 711 Montana
Posest
Montana
the dishwasher? Really? Anyone have any other thoughts?
Only if you are not married or get it out of the dishwasher before your significant other finds out what you put in her dishwasher. I got busted leaving a set of valve covers in my wife's dishwasher. Now I cant use it.Boo Hoo for me. Life is good. It actually works on wiring harness' to soften up the tape and wires.
[Re: OzHemi]
#275421
04/03/09 04:11 PM
04/03/09 04:11 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
I've used hand cleaner in the past too. And for simple spot cleaning or to remove stubborn spots I use a scotch brite (with the hand cleaner) or a heavy duty cloth wipes (the type to clean hands) in a can. Oh whatever you do just cover the wiring with something black. There is no need to make a wire harness stand out.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: Posest]
#275422
04/03/09 04:36 PM
04/03/09 04:36 PM
Posts: 5,037 hi
sharpie
Moparts Linguist
Moparts Linguist
hi
humm. interesting. id have thought there would be adverse effects on the plugs or terminals.
[Re: OzHemi]
#275423
04/03/09 05:21 PM
04/03/09 05:21 PM
Posts: 6,516 Santa Cruz, California
Lefty
I've used orange hand cleaner to clean wires before
Me three, works great and makes the cladding soft and supple. I saturate a shop towel with the cleaner, wipe em down and rinse with water.
[Re: Lefty]
#275424
04/04/09 05:53 AM
04/04/09 05:53 AM
Posts: 416 Franklin Co. Illinois
runinonmt
I know I'll get flamed for this, but I use NO Touch tire care. Works quite well. Ron
In sixty-five I was seventeen and running up one-o-one
I don't know where I'm running now, I'm just running on
Jackson Browne-Running On Empty
