cleaning under-hood wiring? #275412
04/02/09 08:07 PM
04/02/09 08:07 PM
hi
sharpie Offline OP
Moparts Linguist
sharpie  Offline OP
Moparts Linguist
hi
How did you/would you go about it? The slant is leaving sometime within a couple of weeks, and I will have some time with an empty engine bay. I'm not really looking for a factory look, but I'd like to find out how the rest of you first took off the dirt/grime and then how you either dressed it up or cleaned up the wiring mess. Thanks in advance!
Re: cleaning under-hood wiring? [Re: sharpie] #275413
04/02/09 08:27 PM
04/02/09 08:27 PM
Kentucky
dfsmopars Offline
dfsmopars  Offline
Kentucky
I take plenty of pictures. I make sure I have a wiring diagram and then I go to unwrapping the "tape". Everything under the wrap should be clean. What is not clean I use mineral spirits to remove the grease and then wash it all in soapy water. After everything is clean and inspected I wrap it back the way I found it. It is not as big a job as it appears at first.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring
‘14 Big Horn, Quad Cab, 4x4, 1500
Re: cleaning under-hood wiring? [Re: sharpie] #275414
04/02/09 08:28 PM
04/02/09 08:28 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Straight Simple Green and lots of rubbing. For more resistant areas, I used lacquer thinner, but only sparingly. Re-wrap as necessary for a clean look.
Re: cleaning under-hood wiring? [Re: In_The_Pink] #275415
04/02/09 09:18 PM
04/02/09 09:18 PM
Cleveland,Ohio
CtownChris Offline
CtownChris  Offline
Cleveland,Ohio
Wipe heavy grim off with rag and degrease (simple green) then top rack of dish washer.
"Always go forward: Never go straight"
Re: cleaning under-hood wiring? [Re: CtownChris] #275416
04/03/09 12:43 PM
04/03/09 12:43 PM
hi
sharpie Offline OP
Moparts Linguist
sharpie  Offline OP
Moparts Linguist
hi
the dishwasher? Really? Anyone have any other thoughts?
Re: cleaning under-hood wiring? [Re: sharpie] #275417
04/03/09 02:11 PM
04/03/09 02:11 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I'm going to be cleaning wiring in the near future too.
So what wiring does everyone re-use and what wiring do you recomend replacing? Even the wiring that looks NEW is still 35+ years old.
Re: cleaning under-hood wiring? [Re: burdar] #275418
04/03/09 02:55 PM
04/03/09 02:55 PM
Mechanic Falls, Maine
4BBodies Offline
mopar addict
4BBodies  Offline
mopar addict
I cleaned with laquer thinner, repaired wires, and tested. I re-wrapped where necessary, taped all the color wires and connectors, and semi-gloss blacked wherever the wrap was worn looking. This is the only good wire shot I could find, you can see the original colored wire on the cruise servo, but the harness is painted.
Re: cleaning under-hood wiring? [Re: sharpie] #275419
04/03/09 03:20 PM
04/03/09 03:20 PM
Montana
P
Posest Offline
Posest  Offline
P
Montana
Only if you are not married or get it out of the dishwasher before your significant other finds out what you put in her dishwasher. I got busted leaving a set of valve covers in my wife's dishwasher. Now I cant use it.Boo Hoo for me. Life is good. It actually works on wiring harness' to soften up the tape and wires.
Re: cleaning under-hood wiring? [Re: sharpie] #275420
04/03/09 03:35 PM
04/03/09 03:35 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
I've used orange hand cleaner to clean wires before
Re: cleaning under-hood wiring? [Re: OzHemi] #275421
04/03/09 04:11 PM
04/03/09 04:11 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
I've used hand cleaner in the past too.
And for simple spot cleaning or to remove stubborn spots I use a scotch brite (with the hand cleaner) or a heavy duty cloth wipes (the type to clean hands) in a can.
Oh whatever you do just cover the wiring with something black. There is no need to make a wire harness stand out.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: cleaning under-hood wiring? [Re: Posest] #275422
04/03/09 04:36 PM
04/03/09 04:36 PM
hi
sharpie Offline OP
Moparts Linguist
sharpie  Offline OP
Moparts Linguist
hi
humm. interesting. id have thought there would be adverse effects on the plugs or terminals.
Re: cleaning under-hood wiring? [Re: OzHemi] #275423
04/03/09 05:21 PM
04/03/09 05:21 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Me three, works great and makes the cladding soft and supple. I saturate a shop towel with the cleaner, wipe em down and rinse with water.
Re: cleaning under-hood wiring? [Re: Lefty] #275424
04/04/09 05:53 AM
04/04/09 05:53 AM
Franklin Co. Illinois
runinonmt Offline
runinonmt  Offline
I know I'll get flamed for this, but I use NO Touch tire care. Works quite well.
Ron
In sixty-five I was seventeen and running up one-o-one I don't know where I'm running now, I'm just running on Jackson Browne-Running On Empty
