A10 bearings on 8 3/4" axles?
#2728492
12/31/19 10:36 AM
12/31/19 10:36 AM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
What do you know guys about that? I allways have known all 8 3/4" axles uses A7 bearing set, but a friend who need to replace the bearings on his 70 NewYorker had to return the A7 set he got and found he needed the A10 set
Re: A10 bearings on 8 3/4" axles?
[Re: Sniper]
#2728557
12/31/19 02:18 PM
12/31/19 02:18 PM
NachoRT74
Valencia, España
by the PN of the bearing installed, mostly sure by the previous owner, althought he thinks it was still the original from factory
[Re: NachoRT74]
#2728573
12/31/19 03:13 PM
12/31/19 03:13 PM
Posts: 25,858 Rio Linda, CA
John_Kunkel
Rio Linda, CA
A-10 is mostly for GM and Jeeps.
[Re: John_Kunkel]
#2728812
01/01/20 06:36 AM
01/01/20 06:36 AM
NachoRT74
Valencia, España
Definitely he was wrong thinking it was the factory assembly still on car. Sent me a pic of the axle and bearings were installed REVERSED, with small end cone toward inside... of course the adjuster plate got damaged too.
