A10 bearings on 8 3/4" axles? #2728492
12/31/19 10:36 AM
12/31/19 10:36 AM
Valencia, España
NachoRT74 Offline OP
Valencia, España
What do you know guys about that? I allways have known all 8 3/4" axles uses A7 bearing set, but a friend who need to replace the bearings on his 70 NewYorker had to return the A7 set he got and found he needed the A10 set
Re: A10 bearings on 8 3/4" axles? [Re: NachoRT74] #2728497
12/31/19 11:05 AM
12/31/19 11:05 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Only difference is the width of the bearing A10 is narrower, not sure why he thought an A7 was wrong.
Re: A10 bearings on 8 3/4" axles? [Re: Sniper] #2728557
12/31/19 02:18 PM
12/31/19 02:18 PM
Valencia, España
Valencia, España
by the PN of the bearing installed, mostly sure by the previous owner, althought he thinks it was still the original from factory
Re: A10 bearings on 8 3/4" axles? [Re: NachoRT74] #2728573
12/31/19 03:13 PM
12/31/19 03:13 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
A-10 is mostly for GM and Jeeps.
Re: A10 bearings on 8 3/4" axles? [Re: John_Kunkel] #2728812
01/01/20 06:36 AM
01/01/20 06:36 AM
Valencia, España
Valencia, España
Definitely he was wrong thinking it was the factory assembly still on car. Sent me a pic of the axle and bearings were installed REVERSED, with small end cone toward inside... of course the adjuster plate got damaged too.
Re: A10 bearings on 8 3/4" axles? [Re: NachoRT74] #2728846
01/01/20 09:23 AM
01/01/20 09:23 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
kinda wondered what was going on, seems someone before him messed things up and now he gets to deal with it, been there, done that.
Re: A10 bearings on 8 3/4" axles? [Re: Sniper] #2728992
01/01/20 02:24 PM
01/01/20 02:24 PM
Valencia, España
Valencia, España
yes, exactly that.
