What do you know guys about that? I allways have known all 8 3/4" axles uses A7 bearing set, but a friend who need to replace the bearings on his 70 NewYorker had to return the A7 set he got and found he needed the A10 set
With a Charger born in Chrysler assembly plant in Valencia, Venezuela
