Re: Torque Spec for Bango Bolts
[Re: ngpSatellite]
#2550228
09/15/18 10:22 AM
09/15/18 10:22 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Everything has a torque spec, it's in the FSM.
Since you neglect to specify the application I looked up a 73 A body,
25 ft/lbs with a new gasket.
[Re: Supercuda]
#2550304
09/15/18 01:53 PM
09/15/18 01:53 PM
Posts: 25,748 Rio Linda, CA
John_Kunkel
Rio Linda, CA
moparx's advice isn't that far off, I have never had much luck using the factory torque spec. With brand new hoses, new gaskets and new Banjo bolts I usually have leaks when using the factory recommended torque; even tightening them to the point of snapping off still doesn't work. I've finally resorted to using rubber gasket/washers.
[Re: ngpSatellite]
#2550309
09/15/18 02:05 PM
09/15/18 02:05 PM
Supercuda
About to go away
About to go away
up yours
If you use copper washers that are too thin then you get that problem.
Seems the washers provided with new hoses are too think.
Go get some thicker copper sealing washers.
[Re: NANKET]
#2550344
09/15/18 04:31 PM
09/15/18 04:31 PM
John_Kunkel
Rio Linda, CA
I din't say "rubber washers", I said rubber gasket/washers like those pictured below, often called Stat-O-Seals. I tested the rubber's endurance by soaking a couple of them in DOT 3 for six months.
[Re: ngpSatellite]
#2550358
09/15/18 05:27 PM
09/15/18 05:27 PM
Supercuda
About to go away
About to go away
up yours
And the OEM's tested copper sealing washers for decades, still using them today.
Wonder why they still use them?
[Re: Supercuda]
#2550669
09/16/18 04:40 PM
09/16/18 04:40 PM
John_Kunkel
Rio Linda, CA
Wonder why they still use them? While you're at it, wonder why the internet forums are full of queries about leaking copper gaskets. Must be that "everybody" is not as savvy as you (me included). And, if you want to argue "why didn't the factory........?" you might as well cancel your links to all internet forums. There are lots of examples of improvements on the factory.
[Re: NANKET]
#2550754
09/16/18 08:37 PM
09/16/18 08:37 PM
John_Kunkel
Rio Linda, CA
Yes resistant to swelling and deterioration from oil, fuel, coolant, fire, etc, etc.
Please be wary of ANY product recommendations you see on these forums, folks. There is a reason auto manufactures don't use rubber to seal brake line fittings. Oh, and what's the reason?
