Page 1 of 2 1 2 >
#2550138 - 09/14/18 09:29 PM Torque Spec for Bango Bolts
ngpSatellite Offline
Loc: own private Idaho
Doing a disc brake conversion... wondering if any know the torque spec for the bango bolts??
#2550143 - 09/14/18 09:41 PM Re: Torque Spec for Bango Bolts [Re: ngpSatellite]
70Duster Offline
Loc: PA
Banjo bolts come in many different sizes, for many different applications, so the torque spec. varies with the bolt size. Generally, just tight enough so it doesn't leak is the rule of thumb. How irregular the sealing surface on the caliper is also a factor. The rougher the surface, the tighter it will need to be to seal.
#2550202 - 09/15/18 04:37 AM Re: Torque Spec for Bango Bolts [Re: ngpSatellite]
Thanks for the info!!
#2550228 - 09/15/18 08:22 AM Re: Torque Spec for Bango Bolts [Re: ngpSatellite]
Supercuda Offline
I want my mommy!!
Loc: up yours
Everything has a torque spec, it's in the FSM.
Since you neglect to specify the application I looked up a 73 A body,
25 ft/lbs with a new gasket.
Don't be the exception.
#2550278 - 09/15/18 10:49 AM Re: Torque Spec for Bango Bolts [Re: Supercuda]
moparx Offline
Dreaming of implants
Loc: north of coder
you know that isn't correct ! tsk it needs tightened up until it strips, or breaks, then back it off 1/2 turn. ..... biggrin
beer
#2550282 - 09/15/18 11:00 AM Re: Torque Spec for Bango Bolts [Re: moparx]
Loc: Lincoln Nebraska
The weekend is here!
#2550293 - 09/15/18 11:24 AM Re: Torque Spec for Bango Bolts [Re: moparx]
Supercuda Offline
I want my mommy!!
Loc: up yours
beer
boogie
#2550304 - 09/15/18 11:53 AM Re: Torque Spec for Bango Bolts [Re: Supercuda]
John_Kunkel Offline
Loc: Rio Linda, CA
moparx's advice isn't that far off, I have never had much luck using the factory torque spec. With brand new hoses, new gaskets and new Banjo bolts I usually have leaks when using the factory recommended torque; even tightening them to the point of snapping off still doesn't work. I've finally resorted to using rubber gasket/washers.
I'm supposed to respect my elders, but its getting harder and harder for me to find one now.
#2550306 - 09/15/18 11:55 AM Re: Torque Spec for Bango Bolts [Re: ngpSatellite]
BDW Offline
Loc: Florida
Where do you find a rubber gasket that works?
#2550309 - 09/15/18 12:05 PM Re: Torque Spec for Bango Bolts [Re: ngpSatellite]
Supercuda Offline
I want my mommy!!
Loc: up yours
If you use copper washers that are too thin then you get that problem.
Seems the washers provided with new hoses are too think.
Go get some thicker copper sealing washers.
#2550317 - 09/15/18 12:21 PM Re: Torque Spec for Bango Bolts [Re: ngpSatellite]
mopars4ever Offline
Loc: md
I found that a lot of the copper washers that come with reman calipers aren`t worth a crap. They are thinner and seem harder. I use the mopar ones and they have worked fine for me. Sometimes you have to tighten them and loosen and tighten again to help them seat.
#2550321 - 09/15/18 12:32 PM Re: Torque Spec for Bango Bolts [Re: mopars4ever]
bonefish Offline
Loc: s.w.fl
iagreewith this
#2550340 - 09/15/18 01:56 PM Re: Torque Spec for Bango Bolts [Re: ngpSatellite]
NANKET Online   work
Loc: northwest USA
Please don't use rubber washers on your brake system, or recommend this to others. Use metal sealing washers.
#2550344 - 09/15/18 02:31 PM Re: Torque Spec for Bango Bolts [Re: NANKET]
John_Kunkel Offline
Loc: Rio Linda, CA
I din't say "rubber washers", I said rubber gasket/washers like those pictured below, often called Stat-O-Seals. I tested the rubber's endurance by soaking a couple of them in DOT 3 for six months.
#2550355 - 09/15/18 03:13 PM Re: Torque Spec for Bango Bolts [Re: ngpSatellite]
haha... their 3/8 inch bango's,,,,, I'm gonna look for these gasket washers... who has them?
update found them.....
https://www.pegasusautoracing.com/productselection.asp?
Edited by ngpSatellite (09/15/18 03:38 PM)
#2550358 - 09/15/18 03:27 PM Re: Torque Spec for Bango Bolts [Re: ngpSatellite]
Supercuda Offline
I want my mommy!!
Loc: up yours
And the OEM's tested copper sealing washers for decades, still using them today.
Wonder why they still use them?
#2550371 - 09/15/18 04:13 PM Re: Torque Spec for Bango Bolts [Re: ngpSatellite]
NANKET Online   work
Loc: northwest USA
Yes resistant to swelling and deterioration from oil, fuel, coolant, fire, etc, etc.
Please be wary of ANY product recommendations you see on these forums, folks. There is a reason auto manufactures don't use rubber to seal brake line fittings.
#2550669 - 09/16/18 02:40 PM Re: Torque Spec for Bango Bolts [Re: Supercuda]
John_Kunkel Offline
Loc: Rio Linda, CA
While you're at it, wonder why the internet forums are full of queries about leaking copper gaskets. Must be that "everybody" is not as savvy as you (me included).
And, if you want to argue "why didn't the factory........?" you might as well cancel your links to all internet forums. There are lots of examples of improvements on the factory.
#2550754 - 09/16/18 06:37 PM Re: Torque Spec for Bango Bolts [Re: NANKET]
John_Kunkel Offline
Loc: Rio Linda, CA
Oh, and what's the reason?
#2550893 - 09/17/18 12:44 AM Re: Torque Spec for Bango Bolts [Re: ngpSatellite]
RTSrunner Offline
Loc: Pittsburgh,PA
The Harley's I work on use rubber/metal sealing washers unless it is an ABS brake model,then they are solid washers.
Page 1 of 2 1 2 >
25,699 Registered Members
196,740 Topics
A moment of silence...
by feets
Today at 01:47 PM
Tire fit question on 84 D150
by Hellda84
Today at 11:39 AM
Question about NHRA firewall rules
by moparjoe360.4
Today at 10:50 AM
I need an Ignition timing for Dummies lesson
by MrMayhem
Today at 10:41 AM
