Torque Spec for Bango Bolts #2550138
09/14/18 11:29 PM
09/14/18 11:29 PM
own private Idaho
N
ngpSatellite Offline OP
N
own private Idaho
Doing a disc brake conversion... wondering if any know the torque spec for the bango bolts??
Re: Torque Spec for Bango Bolts [Re: ngpSatellite] #2550143
09/14/18 11:41 PM
09/14/18 11:41 PM
PA
70Duster Offline
70Duster  Offline
PA
Banjo bolts come in many different sizes, for many different applications, so the torque spec. varies with the bolt size. Generally, just tight enough so it doesn't leak is the rule of thumb. How irregular the sealing surface on the caliper is also a factor. The rougher the surface, the tighter it will need to be to seal.
Re: Torque Spec for Bango Bolts [Re: ngpSatellite] #2550202
09/15/18 06:37 AM
09/15/18 06:37 AM
own private Idaho
N
N
own private Idaho
Thanks for the info!!
Re: Torque Spec for Bango Bolts [Re: ngpSatellite] #2550228
09/15/18 10:22 AM
09/15/18 10:22 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Everything has a torque spec, it's in the FSM.
Since you neglect to specify the application I looked up a 73 A body,
25 ft/lbs with a new gasket.
Don't be the exception.
Re: Torque Spec for Bango Bolts [Re: Supercuda] #2550278
09/15/18 12:49 PM
09/15/18 12:49 PM
moparx Offline
moparx  Offline
you know that isn't correct ! tsk it needs tightened up until it strips, or breaks, then back it off 1/2 turn. ..... biggrin
beer
Re: Torque Spec for Bango Bolts [Re: moparx] #2550282
09/15/18 01:00 PM
09/15/18 01:00 PM
The weekend is here!
Re: Torque Spec for Bango Bolts [Re: moparx] #2550293
09/15/18 01:24 PM
09/15/18 01:24 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
beer
boogie
Re: Torque Spec for Bango Bolts [Re: Supercuda] #2550304
09/15/18 01:53 PM
09/15/18 01:53 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
moparx's advice isn't that far off, I have never had much luck using the factory torque spec. With brand new hoses, new gaskets and new Banjo bolts I usually have leaks when using the factory recommended torque; even tightening them to the point of snapping off still doesn't work. I've finally resorted to using rubber gasket/washers.
Re: Torque Spec for Bango Bolts [Re: ngpSatellite] #2550306
09/15/18 01:55 PM
09/15/18 01:55 PM
BDW Offline
BDW  Offline
Where do you find a rubber gasket that works?
Re: Torque Spec for Bango Bolts [Re: ngpSatellite] #2550309
09/15/18 02:05 PM
09/15/18 02:05 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
If you use copper washers that are too thin then you get that problem.
Seems the washers provided with new hoses are too think.
Go get some thicker copper sealing washers.
Re: Torque Spec for Bango Bolts [Re: ngpSatellite] #2550317
09/15/18 02:21 PM
09/15/18 02:21 PM
md
mopars4ever Online content
mopars4ever  Online Content
md
I found that a lot of the copper washers that come with reman calipers aren`t worth a crap. They are thinner and seem harder. I use the mopar ones and they have worked fine for me. Sometimes you have to tighten them and loosen and tighten again to help them seat.
Re: Torque Spec for Bango Bolts [Re: mopars4ever] #2550321
09/15/18 02:32 PM
09/15/18 02:32 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
iagreewith this
Re: Torque Spec for Bango Bolts [Re: ngpSatellite] #2550340
09/15/18 03:56 PM
09/15/18 03:56 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Please don't use rubber washers on your brake system, or recommend this to others. Use metal sealing washers.
Re: Torque Spec for Bango Bolts [Re: NANKET] #2550344
09/15/18 04:31 PM
09/15/18 04:31 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I din't say "rubber washers", I said rubber gasket/washers like those pictured below, often called Stat-O-Seals. I tested the rubber's endurance by soaking a couple of them in DOT 3 for six months.
Re: Torque Spec for Bango Bolts [Re: ngpSatellite] #2550355
09/15/18 05:13 PM
09/15/18 05:13 PM
own private Idaho
N
N
own private Idaho
haha... their 3/8 inch bango's,,,,, I'm gonna look for these gasket washers... who has them?
update found them.....
https://www.pegasusautoracing.com/productselection.asp?
Re: Torque Spec for Bango Bolts [Re: ngpSatellite] #2550358
09/15/18 05:27 PM
09/15/18 05:27 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
And the OEM's tested copper sealing washers for decades, still using them today.
Wonder why they still use them?
Re: Torque Spec for Bango Bolts [Re: ngpSatellite] #2550371
09/15/18 06:13 PM
09/15/18 06:13 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Yes resistant to swelling and deterioration from oil, fuel, coolant, fire, etc, etc.
Please be wary of ANY product recommendations you see on these forums, folks. There is a reason auto manufactures don't use rubber to seal brake line fittings.
Re: Torque Spec for Bango Bolts [Re: Supercuda] #2550669
09/16/18 04:40 PM
09/16/18 04:40 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
While you're at it, wonder why the internet forums are full of queries about leaking copper gaskets. Must be that "everybody" is not as savvy as you (me included).
And, if you want to argue "why didn't the factory........?" you might as well cancel your links to all internet forums. There are lots of examples of improvements on the factory.
Re: Torque Spec for Bango Bolts [Re: NANKET] #2550754
09/16/18 08:37 PM
09/16/18 08:37 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Oh, and what's the reason?
Re: Torque Spec for Bango Bolts [Re: ngpSatellite] #2550893
09/17/18 02:44 AM
09/17/18 02:44 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
The Harley's I work on use rubber/metal sealing washers unless it is an ABS brake model,then they are solid washers.
