727 tranny question
#254050
03/15/09 08:46 AM
03/15/09 08:46 AM
Posts: 428 Mountain City, TN
JesseR
Mountain City, TN
What causes fluid to blow out of the vent hole on the pump? This is a new tranny in a friends car, I not a transmission guy so has anybody got an idea whats going on? It has a TA brake in it, don't know the line pressure. This was bought online off of someone who builds transmissions, Thanks, Jesse
82' dodge pickup with a 499 low deck
Re: 727 tranny question
[Re: JesseR]
#254051
03/15/09 09:11 AM
03/15/09 09:11 AM
Posts: 760 Southington Ct.
turbobitt
Southington Ct.
In transbrake applications, the direct drum is drilled for a bleedhole for faster release and ellimination of centrifical apply. Some kits say to drill in the aluminum piston, other say to drill the drum. If the drum is drilled, it can blow fluid as it swings by the vent in the pump. If this is the case, you may want to consider a rear vent conversion.
1970 Challenger w/572 Hemi street car and my pride and joy.
1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno.
1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
[Re: turbobitt]
#254053
03/15/09 09:15 AM
03/15/09 09:15 AM
AS stated by turbobitt,normally when a brake is installed the vent on the pump is tapped and plugged and the vent is put in the rear of the trans case.
[Re: VernMotor]
#254056
03/15/09 10:10 AM
03/15/09 10:10 AM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
vent need to be move to the rear of the case.
I put mine on the tail shaft just behind the cross member.
[Re: VernMotor]
#254057
03/15/09 10:11 AM
03/15/09 10:11 AM
JesseR
Mountain City, TN
Thanks fellas, dad and were talking about the vent needing to be moved to the rear so sounds like we will be taking it to our tranny guy assuming the hole thing will need to come apart to put in a rear vent. Thanks for the help, Jesse
[Re: JesseR]
#254058
03/15/09 10:19 AM
03/15/09 10:19 AM
WILD BILL
BROOK PARK, OH
If you put the vent in the tail housing the most you woud need to remove is the front pump and rear housing.
Just keep in mind that there is a "rib" that goes down the top length of the housing. This is the oil passage for the rear bushing. Put the vent off to either side of the rib.
[Re: WILD BILL]
#254059
03/15/09 12:27 PM
03/15/09 12:27 PM
JesseR
Mountain City, TN
Whats the trick to pulling out the front pump, i can't exactly remember how to do it?
