727 tranny question #254050
03/15/09 08:46 AM
03/15/09 08:46 AM
Mountain City, TN
JesseR Offline OP
JesseR  Offline OP
Mountain City, TN
What causes fluid to blow out of the vent hole on the pump? This is a new tranny in a friends car, I not a transmission guy so has anybody got an idea whats going on? It has a TA brake in it, don't know the line pressure. This was bought online off of someone who builds transmissions, Thanks, Jesse
82' dodge pickup with a 499 low deck
Re: 727 tranny question [Re: JesseR] #254051
03/15/09 09:11 AM
03/15/09 09:11 AM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
In transbrake applications, the direct drum is drilled for a bleedhole for faster release and ellimination of centrifical apply. Some kits say to drill in the aluminum piston, other say to drill the drum. If the drum is drilled, it can blow fluid as it swings by the vent in the pump. If this is the case, you may want to consider a rear vent conversion.
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
Re: 727 tranny question [Re: JesseR] #254052
03/15/09 09:14 AM
03/15/09 09:14 AM
Wyoming Michigan
The Beekeeper Offline
Wyoming Michigan
excessive heat is the first thing that comes to mind, how does the trans preform? and noticeable binding or dragging during operation? are you sure the fluid is comming from the vent? I ran into a front fluid leak issue where after a new front seal and then a front pump assy I had the convertor checked where they found a small crack in the snout..............Tom.
Re: 727 tranny question [Re: turbobitt] #254053
03/15/09 09:15 AM
03/15/09 09:15 AM
AS stated by turbobitt,normally when a brake is installed the vent on the pump is tapped and plugged and the vent is put in the rear of the trans case.
Re: 727 tranny question [Re: JesseR] #254054
03/15/09 09:17 AM
03/15/09 09:17 AM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
vent need to be move to the rear of the case.
Re: 727 tranny question [Re: VernMotor] #254055
03/15/09 10:01 AM
03/15/09 10:01 AM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
is it over full??
Have to start with the basics.
Kasey
Re: 727 tranny question [Re: VernMotor] #254056
03/15/09 10:10 AM
03/15/09 10:10 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I put mine on the tail shaft just behind the cross member.
Re: 727 tranny question [Re: VernMotor] #254057
03/15/09 10:11 AM
03/15/09 10:11 AM
Mountain City, TN
JesseR Offline OP
JesseR  Offline OP
Mountain City, TN
Thanks fellas, dad and were talking about the vent needing to be moved to the rear so sounds like we will be taking it to our tranny guy assuming the hole thing will need to come apart to put in a rear vent. Thanks for the help, Jesse
Re: 727 tranny question [Re: JesseR] #254058
03/15/09 10:19 AM
03/15/09 10:19 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
If you put the vent in the tail housing the most you woud need to remove is the front pump and rear housing.
Just keep in mind that there is a "rib" that goes down the top length of the housing. This is the oil passage for the rear bushing. Put the vent off to either side of the rib.
Re: 727 tranny question [Re: WILD BILL] #254059
03/15/09 12:27 PM
03/15/09 12:27 PM
Mountain City, TN
JesseR Offline OP
JesseR  Offline OP
Mountain City, TN
Whats the trick to pulling out the front pump, i can't exactly remember how to do it?
Re: 727 tranny question [Re: JesseR] #254060
03/15/09 01:02 PM
03/15/09 01:02 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
this 3/8 ; slidehammer
