Indy Block oil dipstick ???????? #2537902
08/17/18 10:13 PM
08/17/18 10:13 PM
birdtracker Offline OP
wondering how people keep track of oil level or add a dip stick to check oil level on an Indy block. Asking for a friend. birdtracker
Re: Indy Block oil dipstick ???????? [Re: birdtracker] #2537928
08/17/18 11:20 PM
08/17/18 11:20 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
I would weld one into the sump.
1963 Plymouth Max Wedge
1971 Barracuda
Re: Indy Block oil dipstick ???????? [Re: birdtracker] #2537929
08/17/18 11:21 PM
08/17/18 11:21 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I put one in the pan kickout.
Doug
Re: Indy Block oil dipstick ???????? [Re: dvw] #2537944
08/18/18 12:19 AM
08/18/18 12:19 AM
Like truck pan with a fitting. Still asking for a friend. Birdtracker
Re: Indy Block oil dipstick ???????? [Re: birdtracker] #2538070
08/18/18 12:15 PM
08/18/18 12:15 PM
Indiana
Gabby63 Offline
Gabby63  Offline
Indiana
When I got my block I was asked if I wanted this provision milled into the block , I chose to put it in there . Did not want to modify my new pan , not that it is the wrong thing to do but why change . Gary
Re: Indy Block oil dipstick ???????? [Re: Gabby63] #2538079
08/18/18 12:28 PM
08/18/18 12:28 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
a dipstick is a potential vacuum leak.. maybe a sight window in oil pan
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Indy Block oil dipstick ???????? [Re: WHITEDART] #2538085
08/18/18 12:35 PM
08/18/18 12:35 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
No dipstick in mine - it holds anywhere from 8/10 qts and if it's not leaking any oil and you change oil mid season why do you need to check it? I have a vacuum pump and it pulls a small amount of oil each run so if you kind of keep track of what comes out then add a little every now and then.
Re: Indy Block oil dipstick ???????? [Re: birdtracker] #2538094
08/18/18 12:51 PM
08/18/18 12:51 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
no dipstick needed
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Indy Block oil dipstick ???????? [Re: birdtracker] #2538134
08/18/18 02:15 PM
08/18/18 02:15 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I disagree. I wouldn't run without a dipstick. All engines use oil. Mine is a factory late model Mopar tube and stick with and o ring at the top. Seals fine with the vacuum pump. Previous to this freshen it used a quart every 25 passes including what dumped into the vacuum overflow. Never smoked, plugs were clean, had good power. That's scary without measuring the level. Currently a 10 qt fill with 1 1/2-2qts in the accumulator shows 7-7 1/qts on the stick. the stick was calibrated by adding one quart at a time on the bench. With 6 1/2qts on the stick, the gauge will fluctuate on hard braking. And that's with trap doors and a swinging pick-up. Makes you think? This motors rod bearings look like new at every check I've ever made, over 550 passes 4.5" stroke, 7200rpm.
Doug
Re: Indy Block oil dipstick ???????? [Re: birdtracker] #2538223
08/18/18 07:56 PM
08/18/18 07:56 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Well a dipstick is without a doubt a potential vacuum leak, does that mean it will leak not necessarily. FWIW I've never run a dipstick on an aftermarket block, just for that reason. If you feel the need to use one then by all means do, just remember it is a potential area for vacuum to leak.
Re: Indy Block oil dipstick ???????? [Re: birdtracker] #2538257
08/18/18 10:00 PM
08/18/18 10:00 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I've never used a dipstick on a race motor. If I were worried about it, I'd put a plug in the pan like a rear end uses.
Re: Indy Block oil dipstick ???????? [Re: CMcAllister] #2538269
08/18/18 10:26 PM
08/18/18 10:26 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I have a factory lo deck with the dip stick and tube and yes it leaked vaccume, so I removed the dip stick and put a tight fitting rubber cap on the tube and hung the stick in the trailer. that way I can check the oil when I feel the need.
Re: Indy Block oil dipstick ???????? [Re: dartman366] #2538357
08/19/18 12:48 AM
08/19/18 12:48 AM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Exactly what I do with my smallblock
"Just a Bracket car dressed up like a streetcar"
Re: Indy Block oil dipstick ???????? [Re: Just-a-dart] #2538478
08/19/18 11:30 AM
08/19/18 11:30 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
My Indy block came with an 1/8 tapped hole for the dipstick. I took a dipstick cut 4-5 inches off it then took a 1/8 pipe plug cut a dremel wheel slit in it inserted the chunk of dipstick in it and brazed them together. Now I can screw it in to stick the oil. Although I think I only did it one or twice over the years.
Re: Indy Block oil dipstick ???????? [Re: B1MAXX] #2538514
08/19/18 12:56 PM
08/19/18 12:56 PM
NY
challenger451ci Offline
NY
I threaded my block 1/8" NPT and made a dipstick tube out of steel brake line. The top is sealed up with a pipe plug. Seems to hold vacuum.
Re: Indy Block oil dipstick ???????? [Re: birdtracker] #2538648
08/19/18 07:54 PM
08/19/18 07:54 PM
Stuttgart, Arkansas
rickseeman Online content
rickseeman  Online Content
Stuttgart, Arkansas
Mine came with a normal dipstick I guess.
2011 Drag Pak Challenger
