Re: Indy Block oil dipstick ????????
[Re: birdtracker]
#2537928
08/17/18 11:20 PM
08/17/18 11:20 PM
Posts: 1,096 Australia
ozymaxwedge
Australia
I would weld one into the sump.
1963 Plymouth Max Wedge 1971 Barracuda
[Re: dvw]
#2537944
08/18/18 12:19 AM
08/18/18 12:19 AM
birdtracker
Like truck pan with a fitting. Still asking for a friend. Birdtracker
[Re: Gabby63]
#2538079
08/18/18 12:28 PM
08/18/18 12:28 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
When I got my block I was asked if I wanted this provision milled into the block , I chose to put it in there . Did not want to modify my new pan , not that it is the wrong thing to do but why change . Gary a dipstick is a potential vacuum leak.. maybe a sight window in oil pan
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: birdtracker]
#2538223
08/18/18 07:56 PM
08/18/18 07:56 PM
Posts: 19,304 Las Vegas
Al_Alguire
Las Vegas
Well a dipstick is without a doubt a potential vacuum leak, does that mean it will leak not necessarily. FWIW I've never run a dipstick on an aftermarket block, just for that reason. If you feel the need to use one then by all means do, just remember it is a potential area for vacuum to leak.
[Re: birdtracker]
#2538257
08/18/18 10:00 PM
08/18/18 10:00 PM
Posts: 11,408 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I've never used a dipstick on a race motor. If I were worried about it, I'd put a plug in the pan like a rear end uses.
[Re: CMcAllister]
#2538269
08/18/18 10:26 PM
08/18/18 10:26 PM
dartman366
Mt. Vernon, Ohio
I have a factory lo deck with the dip stick and tube and yes it leaked vaccume, so I removed the dip stick and put a tight fitting rubber cap on the tube and hung the stick in the trailer. that way I can check the oil when I feel the need.
[Re: dartman366]
#2538357
08/19/18 12:48 AM
08/19/18 12:48 AM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
I have a factory lo deck with the dip stick and tube and yes it leaked vaccume, so I removed the dip stick and put a tight fitting rubber cap on the tube and hung the stick in the trailer. that way I can check the oil when I feel the need. Exactly what I do with my smallblock
"Just a Bracket car dressed up like a streetcar"
