Steel Shim Head Gasket Compressed Thickness?
#2515921
07/01/18 04:22 PM
07/01/18 04:22 PM
Posts: 1,285 Pacific NW USA
CompSyn
Pacific NW USA
I'm trying to figure out what numbers to put into the compression ratio calculator? I have a set of: Mopar Performance Steel Shim Head Gasket Sets P4286754 -link The part number on the actual head gasket is #3614824 The advertised compressed thickness is 0.020" I mic'd them at 0.015" My question is, will the embossing give the gasket a compressed thickness closer to 0.020"? Or will the compressed thickness be closer to what I actually measured; 0.015"?
Re: Steel Shim Head Gasket Compressed Thickness?
[Re: CompSyn]
#2515980
07/01/18 06:24 PM
07/01/18 06:24 PM
RapidRobert
My question is, will the embossing give the gasket a compressed thickness closer to 0.020"? Or will the compressed thickness be closer to what I actually measured; 0.015"? what does the embossed raised ridge mike at?
[Re: RapidRobert]
#2515998
07/01/18 07:07 PM
07/01/18 07:07 PM
CompSyn
Pacific NW USA
My question is, will the embossing give the gasket a compressed thickness closer to 0.020"? Or will the compressed thickness be closer to what I actually measured; 0.015"? what does the embossed raised ridge mike at? The new one is 0.0355" The used original is 0.0195"
[Re: CompSyn]
#2516010
07/01/18 07:33 PM
07/01/18 07:33 PM
Posts: 43,185 Bend,OR USA
Cab_Burge
The OEM 4.320 bore size(measure around 4.410 bore size) 440 stamp steel head gasket is suppose to be .017 compressed The earlier 361, 383, 413 and 426W Mopar OEM stamped steel head gasket was .022 compressed with the 4.320 or so bore size
