Steel Shim Head Gasket Compressed Thickness? #2515921
07/01/18 04:22 PM
07/01/18 04:22 PM
Pacific NW USA
CompSyn Offline OP
CompSyn  Offline OP
Pacific NW USA
I'm trying to figure out what numbers to put into the compression ratio calculator?
I have a set of: Mopar Performance Steel Shim Head Gasket Sets P4286754 -link
The part number on the actual head gasket is #3614824
The advertised compressed thickness is 0.020"
I mic'd them at 0.015"
My question is, will the embossing give the gasket a compressed thickness closer to 0.020"? Or will the compressed thickness be closer to what I actually measured; 0.015"?
Re: Steel Shim Head Gasket Compressed Thickness? [Re: CompSyn] #2515938
07/01/18 05:07 PM
07/01/18 05:07 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
use .015" number. mr.gasket has a .020" gasket if needed; IIRC #1135g.
Re: Steel Shim Head Gasket Compressed Thickness? [Re: CompSyn] #2515980
07/01/18 06:24 PM
07/01/18 06:24 PM
what does the embossed raised ridge mike at?
Re: Steel Shim Head Gasket Compressed Thickness? [Re: RapidRobert] #2515998
07/01/18 07:07 PM
07/01/18 07:07 PM
Pacific NW USA
CompSyn Offline OP
CompSyn  Offline OP
Pacific NW USA
The new one is 0.0355"
The used original is 0.0195"
Re: Steel Shim Head Gasket Compressed Thickness? [Re: CompSyn] #2516010
07/01/18 07:33 PM
07/01/18 07:33 PM
The OEM 4.320 bore size(measure around 4.410 bore size) 440 stamp steel head gasket is suppose to be .017 compressed work
The earlier 361, 383, 413 and 426W Mopar OEM stamped steel head gasket was .022 compressed with the 4.320 or so bore size shruggy
