Removing center link?
#2462943
03/08/18 01:49 AM
03/08/18 01:49 AM
Posts: 136 Ontario, Canada
500ciBee
Ontario, Canada
I need to remove the center link to swap out the headers on my Bee. The center link passes between the tubes of the headers. I'm not sure what is the best method to getting the center link off. I've tried hitting it about as hard as I think is safe. What do you guys suggest?
1970 Super Bee prostreet. 383, SMR 727, Dana 60 4:88. Building a 512 low deck.
Re: Removing center link?
[Re: 500ciBee]
#2463236
03/08/18 06:37 PM
03/08/18 06:37 PM
500ciBee
Ontario, Canada
Thanks! I'll pickup one those.
[Re: 500ciBee]
#2468170
03/18/18 05:10 PM
03/18/18 05:10 PM
500ciBee
Ontario, Canada
I bought a ball joint separator but there is no way the tool will fit between the idler arm and center link. I've hit it enough that I think it should have come apart. Should I remove the idler from the frame?
