Removing center link? #2462943
03/08/18 01:49 AM
03/08/18 01:49 AM
Ontario, Canada
500ciBee Offline OP
500ciBee  Offline OP
Ontario, Canada
I need to remove the center link to swap out the headers on my Bee. The center link passes between the tubes of the headers. I'm not sure what is the best method to getting the center link off. I've tried hitting it about as hard as I think is safe. What do you guys suggest?
1970 Super Bee prostreet. 383, SMR 727, Dana 60 4:88. Building a 512 low deck.
Re: Removing center link? [Re: 500ciBee] #2462951
03/08/18 02:16 AM
03/08/18 02:16 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Removing center link? [Re: 500ciBee] #2463236
03/08/18 06:37 PM
03/08/18 06:37 PM
Ontario, Canada
500ciBee Offline OP
500ciBee  Offline OP
Ontario, Canada
Thanks! I'll pickup one those.
Re: Removing center link? [Re: 500ciBee] #2464185
03/10/18 08:36 AM
03/10/18 08:36 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
You can usually pop ball joints with use of two large (±5 lbs) hammers.
Put one (the largest) hammer behind and hit the metal from the front.
Of course you don't whack the balljoint itself, but the part that it's protruding.
Leave the nut loose on the threads in case you hit it wrong.
Re: Removing center link? [Re: 500ciBee] #2468170
03/18/18 05:10 PM
03/18/18 05:10 PM
Ontario, Canada
500ciBee Offline OP
500ciBee  Offline OP
Ontario, Canada
I bought a ball joint separator but there is no way the tool will fit between the idler arm and center link. I've hit it enough that I think it should have come apart. Should I remove the idler from the frame?
Re: Removing center link? [Re: 500ciBee] #2468198
03/18/18 06:15 PM
03/18/18 06:15 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
May need to tap it in a little. Mine worked perfectly..
2020 RAM 1500
