Page 1 of 3 1 2 3 >
#2442008 - 01/28/18 12:25 AM Dyno update after intake and collector change
WHITEDART Online   laugh2
Loc: bean town ....Ca
https://youtu.be/_DyOgpi596w. Well with all the recent changes it appears we picked up close to 40 average horsepowe.. and over 40 foot pounds torque.. after examining some other video it appears fuel was being pulled out of the squirters.. for the first portion of each pull.. it was a long day and the prosody in the block fought us again.. we chased water in the oil all day.. the block sealer that was plugging the hole apparently washed out..
Edited by WHITEDART (01/28/18 12:33 AM)
In the 8s N/A.with Brett miller W8's
5.42 8.52 159.
#2442009 - 01/28/18 12:28 AM Re: Dyno update after intake and collector change [Re: WHITEDART]
https://youtu.be/a8uquEi3sdk this video shows the fuel being pulled out of the squirters.. which definitely didn't help today's Dyno Adventure
5.42 8.52 159.
#2442040 - 01/28/18 01:07 AM Re: Dyno update after intake and collector change [Re: WHITEDART]
rumblefish72 Offline
Loc: Cranberry Twp PA (North of Pit...
Man - that's a great dyno video to have ... looking down into the venturi. So now that you can see the squirters spraying at WOT, how do you remedy that? There must be lots of air going past the squirters creating enough vacuum to suck fuel out of the accelerator pump circuit. If you're making 900+ HP out of a small block, you must be moving quite a bit of air. Could you change the shape of the squirter output to make it less sensitive to air rushing past it?
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
#2442061 - 01/28/18 01:55 AM Re: Dyno update after intake and collector change [Re: WHITEDART]
tex013 Offline
Loc: Sydney,Australia
I have/had the same pull through . From reading it appears as not unusual . As it only happens at high rpm/throttle/load just jet as needed be secondaries for best afr .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
#2442064 - 01/28/18 02:25 AM Re: Dyno update after intake and collector change [Re: WHITEDART]
Cab_Burge Online   content
Loc: Bend,OR USA
Which type squirters are you using on that carb.now?Maybe it is time to try the other type to see if they will not siphon like these are work
Good luck either way thumbs
#2442113 - 01/28/18 08:39 AM Re: Dyno update after intake and collector change [Re: Cab_Burge]
Deepockets Offline
Loc: glendora, ca.
That's crazy. When fine tuning your mains, it's just gotten a little easier to change your squirters!
#2442114 - 01/28/18 08:48 AM Re: Dyno update after intake and collector change [Re: WHITEDART]
Twostick Offline
Loc: Downtown Roebuck Ont
Have you tried waterglass to seal up the block?
Kevin
#2442126 - 01/28/18 09:13 AM Re: Dyno update after intake and collector change [Re: WHITEDART]
madscientist Online   content
Loc: Washington
Some one makes a part that stops pullover like that. I can't think of who it is but I'm sure someone else will know who it is.
Seems like the part was reasonable price wise too.
#2442128 - 01/28/18 09:17 AM Re: Dyno update after intake and collector change [Re: WHITEDART]
Loc: Washington
I just watched the video and damn, it's pulling a bunch of fuel. I suspect that many times when we think the air bleeds are off at RPM it's going rich because it's pulling fuel from the accelerator pumps.
Thing sounds bitching for sure.
#2442132 - 01/28/18 09:23 AM Re: Dyno update after intake and collector change [Re: WHITEDART]
scottb Offline
Loc: New Smyrna Beach FL
Titan sealer is the best stuff out there its pricey but it works are you using a ritter block dont remember
#2442140 - 01/28/18 09:39 AM Re: Dyno update after intake and collector change [Re: tex013]
Bad340fish Offline
Loc: Tulsa OK
Tex
I would imagine it doesn't happen constantly enough to rely on it. It may not happen in the car as much as on the dyno etc.
Great Video, thank you for sharing!
68 Barracuda Formula S 340
#2442201 - 01/28/18 10:51 AM Re: Dyno update after intake and collector change [Re: WHITEDART]
Al_Alguire Offline
Loc: Las Vegas
BLP as well as others make high flow anti pullover nozzles. Cant believe that Book piece is not using something similar?!?
#2442209 - 01/28/18 11:07 AM Re: Dyno update after intake and collector change [Re: Al_Alguire]
Will you can count on for as much as that carburetor cost he will be getting a phone call on Monday...
5.42 8.52 159.
#2442213 - 01/28/18 11:10 AM Re: Dyno update after intake and collector change [Re: WHITEDART]
Al_Alguire Offline
Loc: Las Vegas
Lots of ways to address that. It is not that unusual for sure
#2442215 - 01/28/18 11:16 AM Re: Dyno update after intake and collector change [Re: WHITEDART]
AndyF Online   content
Loc: Oregon
Yeah I've seen that pullover before and have fought that fight. One more reason I switched over to EFI.
#2442220 - 01/28/18 11:21 AM Re: Dyno update after intake and collector change [Re: WHITEDART]
Thumperdart Offline
Loc: State of confusion
Not uncommon at all and some say it's part of their tune......... beer
#2442243 - 01/28/18 12:01 PM Re: Dyno update after intake and collector change [Re: WHITEDART]
DavidDean Offline
Loc: Lubbock,TX
Very very impressive ! Goodson makes sealer that works very well. I know holley makes an anti pull over shooter. You maybe aware of both. Keep up the good work !
#2442378 - 01/28/18 03:57 PM Re: Dyno update after intake and collector change [Re: scottb]
yes sad to admit it's a Ritter block..
5.42 8.52 159.
#2442433 - 01/28/18 05:49 PM Re: Dyno update after intake and collector change [Re: WHITEDART]
Does anybody have a link.. to the place that sells the squirter specifically.. I would like to take that tuning variable out of the equation.. my gut feeling is it considered early affect the 60-foot
Edited by WHITEDART (01/28/18 05:50 PM)
5.42 8.52 159.
#2442437 - 01/28/18 05:59 PM Re: Dyno update after intake and collector change [Re: WHITEDART]
Sport440 Offline
Loc: Canton, Ohio
No link, but BLP products sell the Hi flow anti pull over nozzles, $14.25 for a pair. They sell lots of carb stuff.
Nice Gain on that engine. That's tough to get a gain like that IMO, with a engine that is already running so well. up
Page 1 of 3 1 2 3 >
25,708 Registered Members
196,877 Topics
ShakerHood.Com
by RROD
01/23/19 03:10 PM
Small Chrome Plating System
by jim6346
01/23/19 02:09 PM
1968 Dart conversion from sedan to hardtop
by maximus
01/23/19 01:15 PM
Tire Diameter Selection
by gzig5
01/23/19 12:08 PM
