Dyno update after intake and collector change
#2442008
01/28/18 03:25 AM
01/28/18 03:25 AM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
https://youtu.be/_DyOgpi596w. Well with all the recent changes it appears we picked up close to 40 average horsepowe.. and over 40 foot pounds torque.. after examining some other video it appears fuel was being pulled out of the squirters.. for the first portion of each pull.. it was a long day and the prosody in the block fought us again.. we chased water in the oil all day.. the block sealer that was plugging the hole apparently washed out..
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
Re: Dyno update after intake and collector change
[Re: WHITEDART]
#2442040
01/28/18 04:07 AM
01/28/18 04:07 AM
Posts: 243 Cranberry Twp PA (North of Pit...
rumblefish72
Man - that's a great dyno video to have ... looking down into the venturi. So now that you can see the squirters spraying at WOT, how do you remedy that? There must be lots of air going past the squirters creating enough vacuum to suck fuel out of the accelerator pump circuit. If you're making 900+ HP out of a small block, you must be moving quite a bit of air. Could you change the shape of the squirter output to make it less sensitive to air rushing past it?
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
[Re: WHITEDART]
#2442061
01/28/18 04:55 AM
01/28/18 04:55 AM
Posts: 2,457 Sydney,Australia
tex013
Sydney,Australia
I have/had the same pull through . From reading it appears as not unusual . As it only happens at high rpm/throttle/load just jet as needed be secondaries for best afr .
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: WHITEDART]
#2442126
01/28/18 12:13 PM
01/28/18 12:13 PM
Posts: 4,457 Washington
madscientist
Washington
Some one makes a part that stops pullover like that. I can't think of who it is but I'm sure someone else will know who it is.
Seems like the part was reasonable price wise too.
[Re: WHITEDART]
#2442128
01/28/18 12:17 PM
01/28/18 12:17 PM
madscientist
Washington
I just watched the video and damn, it's pulling a bunch of fuel. I suspect that many times when we think the air bleeds are off at RPM it's going rich because it's pulling fuel from the accelerator pumps.
Thing sounds bitching for sure.
[Re: tex013]
#2442140
01/28/18 12:39 PM
01/28/18 12:39 PM
Posts: 8,005 Tulsa OK
Bad340fish
Tulsa OK
Tex I would imagine it doesn't happen constantly enough to rely on it. It may not happen in the car as much as on the dyno etc. Great Video, thank you for sharing!
68 Barracuda Formula S 340 87 "Chrysler" Conquest
[Re: WHITEDART]
#2442201
01/28/18 01:51 PM
01/28/18 01:51 PM
Posts: 19,304 Las Vegas
Al_Alguire
Las Vegas
BLP as well as others make high flow anti pullover nozzles. Cant believe that Book piece is not using something similar?!?
[Re: Al_Alguire]
#2442209
01/28/18 02:07 PM
01/28/18 02:07 PM
WHITEDART
bean town ....Ca
Will you can count on for as much as that carburetor cost he will be getting a phone call on Monday...
[Re: WHITEDART]
#2442213
01/28/18 02:10 PM
01/28/18 02:10 PM
Al_Alguire
Las Vegas
Lots of ways to address that. It is not that unusual for sure
[Re: WHITEDART]
#2442220
01/28/18 02:21 PM
01/28/18 02:21 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
https://youtu.be/a8uquEi3sdk this video shows the fuel being pulled out of the squirters.. which definitely didn't help today's Dyno Adventure Not uncommon at all and some say it's part of their tune.........
[Re: scottb]
#2442378
01/28/18 06:57 PM
01/28/18 06:57 PM
WHITEDART
bean town ....Ca
Titan sealer is the best stuff out there its pricey but it works are you using a ritter block dont remember yes sad to admit it's a Ritter block..
[Re: WHITEDART]
#2442433
01/28/18 08:49 PM
01/28/18 08:49 PM
WHITEDART
bean town ....Ca
Does anybody have a link.. to the place that sells the squirter specifically.. I would like to take that tuning variable out of the equation.. my gut feeling is it considered early affect the 60-foot
