Page 1 of 3 1 2 3
Dyno update after intake and collector change #2442008
01/28/18 03:25 AM
01/28/18 03:25 AM
bean town ....Ca
W
WHITEDART Offline OP
W
bean town ....Ca
https://youtu.be/_DyOgpi596w. Well with all the recent changes it appears we picked up close to 40 average horsepowe.. and over 40 foot pounds torque.. after examining some other video it appears fuel was being pulled out of the squirters.. for the first portion of each pull.. it was a long day and the prosody in the block fought us again.. we chased water in the oil all day.. the block sealer that was plugging the hole apparently washed out..
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Dyno update after intake and collector change [Re: WHITEDART] #2442009
01/28/18 03:28 AM
01/28/18 03:28 AM
bean town ....Ca
W
W
bean town ....Ca
https://youtu.be/a8uquEi3sdk this video shows the fuel being pulled out of the squirters.. which definitely didn't help today's Dyno Adventure
Re: Dyno update after intake and collector change [Re: WHITEDART] #2442040
01/28/18 04:07 AM
01/28/18 04:07 AM
Cranberry Twp PA (North of Pit...
rumblefish72 Offline
Man - that's a great dyno video to have ... looking down into the venturi. So now that you can see the squirters spraying at WOT, how do you remedy that? There must be lots of air going past the squirters creating enough vacuum to suck fuel out of the accelerator pump circuit. If you're making 900+ HP out of a small block, you must be moving quite a bit of air. Could you change the shape of the squirter output to make it less sensitive to air rushing past it?
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
Re: Dyno update after intake and collector change [Re: WHITEDART] #2442061
01/28/18 04:55 AM
01/28/18 04:55 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
I have/had the same pull through . From reading it appears as not unusual . As it only happens at high rpm/throttle/load just jet as needed be secondaries for best afr .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Dyno update after intake and collector change [Re: WHITEDART] #2442064
01/28/18 05:25 AM
01/28/18 05:25 AM
Which type squirters are you using on that carb.now?Maybe it is time to try the other type to see if they will not siphon like these are work
Good luck either way thumbs
Re: Dyno update after intake and collector change [Re: Cab_Burge] #2442113
01/28/18 11:39 AM
01/28/18 11:39 AM
glendora, ca.
Deepockets Offline
Deepockets  Offline
glendora, ca.
That's crazy. When fine tuning your mains, it's just gotten a little easier to change your squirters!
Re: Dyno update after intake and collector change [Re: WHITEDART] #2442114
01/28/18 11:48 AM
01/28/18 11:48 AM
Downtown Roebuck Ont
Twostick Online content
Still wishing...
Twostick  Online Content
Still wishing...
Have you tried waterglass to seal up the block?
Kevin
Re: Dyno update after intake and collector change [Re: WHITEDART] #2442126
01/28/18 12:13 PM
01/28/18 12:13 PM
Washington
madscientist Offline
Washington
Some one makes a part that stops pullover like that. I can't think of who it is but I'm sure someone else will know who it is.
Seems like the part was reasonable price wise too.
Re: Dyno update after intake and collector change [Re: WHITEDART] #2442128
01/28/18 12:17 PM
01/28/18 12:17 PM
Washington
Washington
I just watched the video and damn, it's pulling a bunch of fuel. I suspect that many times when we think the air bleeds are off at RPM it's going rich because it's pulling fuel from the accelerator pumps.
Thing sounds bitching for sure.
Re: Dyno update after intake and collector change [Re: WHITEDART] #2442132
01/28/18 12:23 PM
01/28/18 12:23 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
Titan sealer is the best stuff out there its pricey but it works are you using a ritter block dont remember
Re: Dyno update after intake and collector change [Re: tex013] #2442140
01/28/18 12:39 PM
01/28/18 12:39 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Tex
I would imagine it doesn't happen constantly enough to rely on it. It may not happen in the car as much as on the dyno etc.
Great Video, thank you for sharing!
68 Barracuda Formula S 340
Re: Dyno update after intake and collector change [Re: WHITEDART] #2442201
01/28/18 01:51 PM
01/28/18 01:51 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
BLP as well as others make high flow anti pullover nozzles. Cant believe that Book piece is not using something similar?!?
Re: Dyno update after intake and collector change [Re: Al_Alguire] #2442209
01/28/18 02:07 PM
01/28/18 02:07 PM
bean town ....Ca
W
W
bean town ....Ca
Will you can count on for as much as that carburetor cost he will be getting a phone call on Monday...
Re: Dyno update after intake and collector change [Re: WHITEDART] #2442213
01/28/18 02:10 PM
01/28/18 02:10 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Lots of ways to address that. It is not that unusual for sure
Re: Dyno update after intake and collector change [Re: WHITEDART] #2442215
01/28/18 02:16 PM
01/28/18 02:16 PM
AndyF Offline
AndyF  Offline
Yeah I've seen that pullover before and have fought that fight. One more reason I switched over to EFI.
Re: Dyno update after intake and collector change [Re: WHITEDART] #2442220
01/28/18 02:21 PM
01/28/18 02:21 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Not uncommon at all and some say it's part of their tune......... beer
Re: Dyno update after intake and collector change [Re: WHITEDART] #2442243
01/28/18 03:01 PM
01/28/18 03:01 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
Very very impressive ! Goodson makes sealer that works very well. I know holley makes an anti pull over shooter. You maybe aware of both. Keep up the good work !
Re: Dyno update after intake and collector change [Re: scottb] #2442378
01/28/18 06:57 PM
01/28/18 06:57 PM
bean town ....Ca
W
W
bean town ....Ca
yes sad to admit it's a Ritter block..
Re: Dyno update after intake and collector change [Re: WHITEDART] #2442433
01/28/18 08:49 PM
01/28/18 08:49 PM
bean town ....Ca
W
W
bean town ....Ca
Does anybody have a link.. to the place that sells the squirter specifically.. I would like to take that tuning variable out of the equation.. my gut feeling is it considered early affect the 60-foot
Re: Dyno update after intake and collector change [Re: WHITEDART] #2442437
01/28/18 08:59 PM
01/28/18 08:59 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
No link, but BLP products sell the Hi flow anti pull over nozzles, $14.25 for a pair. They sell lots of carb stuff.
Nice Gain on that engine. That's tough to get a gain like that IMO, with a engine that is already running so well. up
Page 1 of 3 1 2 3
