#2448098 - 02/07/18 02:32 PM Where to install intake cl on this cam.
galen Offline
Loc: Missouri
Street car cruise night/weekend warrior.. Heavy 68 satellite. automatic 3500 stall 3.73 gears. 470 low deck, trick flow 270 heads. 10.5 compression. Indy 400-2, tti headers. Cam is mechanical roller 264/270 at .050. .660/.630 lift 112lsa. ground straight up no advance. I know its not optimum but I have it lying around. Would you install intake cl straight up at 112 or advance or retard a few degrees and why. Also have an old isky mech roller 272/272 .050 .630 on a 108. Just want to use what I have
on hand for now. Thanks, Galen
#2448103 - 02/07/18 02:38 PM Re: Where to install intake cl on this cam. [Re: galen]
fast68plymouth Online   content
Loc: So. Burlington, Vt.
You have to start somewhere...... For me that would be 108.
68 Plymouth Satellite, 383, stock 906's, 3550lbs, 11.18 @ 123, 1.51 60'
WD- Comp Cams / Indy Cylinder Heads
#2448114 - 02/07/18 02:55 PM Re: Where to install intake cl on this cam. [Re: fast68plymouth]
galen Offline
Loc: Missouri
Thank you.
#2448313 - 02/07/18 10:49 PM Re: Where to install intake cl on this cam. [Re: galen]
polyspheric Offline
Loc: New York
ICL minus 4° is very common, good place to start, in fact some manufacturers assume you will do this.
Boffin Emeritus
#2448334 - 02/08/18 12:12 AM Re: Where to install intake cl on this cam. [Re: galen]
451Mopar Offline
Loc: Aurora, Colorado
110.5 would be split overlap with intake opening and exhaust closing are both 21.5 degrees @ 0.050. I would start around 108 ICL. With your cars weight, mild gearing, and moderate compression the car may run better advanced even more.
#2448353 - 02/08/18 01:52 AM Re: Where to install intake cl on this cam. [Re: galen]
Loc: Bend,OR USA
I would probably use the Isky cam in your deal and installed it between 103 to 105 ICL, what ever you can get with your timing set up twocents
Those old Isky lobes open very slowly so V to P shouldn't be any problem but check it anyways, of course grin
#2448492 - 02/08/18 10:44 AM Re: Where to install intake cl on this cam. [Re: galen]
Clanton Offline
Loc: northern,Ohio,USA
My cam is sorta close to yours and I am n/a now w/victor intake,h 850cfm 3.73/28" tires 446" but a 5k stall 9.5 vert and I spin the tires at will.[edl std port ported heads]cam is in at 108
ps;here is a video go to 1:33 and it spins at 3500 rpm at 1/2 to 3/4 throttle. test drive
Edited by Clanton (02/08/18 01:03 PM)
#2448497 - 02/08/18 10:52 AM Re: Where to install intake cl on this cam. [Re: Cab_Burge]
an8sec70cuda Offline
Loc: Marion, South Carolina [><]
iagree I was thinking the same thing. The old Isky cam in around 104°. up
CHIP
'70 hemicuda street car...8.91 at 150.5 mph w/ 4.10s, 8.97 at 152.5 mph w/ 3.54s so far
'69 road runner 440 w/ Indy SRs
'69 road runner 440-6, 4 speed...Dad's ride
'71 Demon 340 resto project
'06 GMC 2500HD LBZ Duramax...toy hauler
'16 Grand Caravan SXT...baby hauler
#2448509 - 02/08/18 11:27 AM Re: Where to install intake cl on this cam. [Re: galen]
272/272 is pretty big for 10.5cr, 3500 stall, and 3.73 gears...... Especially when topped by a 400-2.
The 264/270-112 isn't ideal either IMO.
If its really only 3500 flash stall, I'd expect something about 10deg smaller on a 108-110 would be quicker in the car.
#2448556 - 02/08/18 12:45 PM Re: Where to install intake cl on this cam. [Re: galen]
Clanton Offline
^ Being a street car I can see your point but I was unsure if the little more stroke would like it with the 264/270
#2448567 - 02/08/18 01:06 PM Re: Where to install intake cl on this cam. [Re: Clanton]
galen Offline
Loc: Missouri
Thanks for the input everyone. My trans is a tci 6x. gear ratios are 2.97,2.23,1.57,1.18,1.00,0.75. Only reason I am holding off on a new cam is I am hoping to go Holley HP efi. I know that will require a matching camshaft when the time comes.
#2448568 - 02/08/18 01:08 PM Re: Where to install intake cl on this cam. [Re: galen]
With 3.73's and a .75 OD an even smaller cam would be prefered for a more favorable cruise RPM, IMO.
#2448687 - 02/08/18 05:38 PM Re: Where to install intake cl on this cam. [Re: fast68plymouth]
galen Offline
Loc: Missouri
Dwayne I sent you a pm.
25,743 Registered Members
193,023 Topics
Who sells A-Body Rear Leaf Spring Rebuild Kits?
by vinnyd76
Today at 09:58 AM
Rich Edelebrocks
by moparjack44
Today at 09:37 AM
Converting a 12 volt battery to 16 volt
by Sammy
Today at 08:50 AM
What brand Ring & Pinion are you running in your 8.75 rear?
by vinnyd76
Today at 08:49 AM
