Where to install intake cl on this cam. #2448098
02/07/18 05:32 PM
02/07/18 05:32 PM
Missouri
galen Offline OP
galen  Offline OP
Missouri
Street car cruise night/weekend warrior.. Heavy 68 satellite. automatic 3500 stall 3.73 gears. 470 low deck, trick flow 270 heads. 10.5 compression. Indy 400-2, tti headers. Cam is mechanical roller 264/270 at .050. .660/.630 lift 112lsa. ground straight up no advance. I know its not optimum but I have it lying around. Would you install intake cl straight up at 112 or advance or retard a few degrees and why. Also have an old isky mech roller 272/272 .050 .630 on a 108. Just want to use what I have
on hand for now. Thanks, Galen
Re: Where to install intake cl on this cam. [Re: galen] #2448103
02/07/18 05:38 PM
02/07/18 05:38 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
You have to start somewhere...... For me that would be 108.
Re: Where to install intake cl on this cam. [Re: fast68plymouth] #2448114
02/07/18 05:55 PM
02/07/18 05:55 PM
Missouri
galen Offline OP
galen  Offline OP
Missouri
Thank you.
Re: Where to install intake cl on this cam. [Re: galen] #2448313
02/08/18 01:49 AM
02/08/18 01:49 AM
New York
polyspheric Offline
polyspheric  Offline
New York
ICL minus 4° is very common, good place to start, in fact some manufacturers assume you will do this.
Boffin Emeritus
Re: Where to install intake cl on this cam. [Re: galen] #2448334
02/08/18 03:12 AM
02/08/18 03:12 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
110.5 would be split overlap with intake opening and exhaust closing are both 21.5 degrees @ 0.050. I would start around 108 ICL. With your cars weight, mild gearing, and moderate compression the car may run better advanced even more.
Re: Where to install intake cl on this cam. [Re: galen] #2448353
02/08/18 04:52 AM
02/08/18 04:52 AM
Cab_Burge Online work
Cab_Burge  Online Work
I would probably use the Isky cam in your deal and installed it between 103 to 105 ICL, what ever you can get with your timing set up twocents
Those old Isky lobes open very slowly so V to P shouldn't be any problem but check it anyways, of course grin
Re: Where to install intake cl on this cam. [Re: galen] #2448492
02/08/18 01:44 PM
02/08/18 01:44 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
My cam is sorta close to yours and I am n/a now w/victor intake,h 850cfm 3.73/28" tires 446" but a 5k stall 9.5 vert and I spin the tires at will.[edl std port ported heads]cam is in at 108
ps;here is a video go to 1:33 and it spins at 3500 rpm at 1/2 to 3/4 throttle. test drive
Re: Where to install intake cl on this cam. [Re: Cab_Burge] #2448497
02/08/18 01:52 PM
02/08/18 01:52 PM
an8sec70cuda Offline
iagree I was thinking the same thing. The old Isky cam in around 104°. up
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Where to install intake cl on this cam. [Re: galen] #2448509
02/08/18 02:27 PM
02/08/18 02:27 PM
So. Burlington, Vt.
So. Burlington, Vt.
272/272 is pretty big for 10.5cr, 3500 stall, and 3.73 gears...... Especially when topped by a 400-2.
The 264/270-112 isn't ideal either IMO.
If its really only 3500 flash stall, I'd expect something about 10deg smaller on a 108-110 would be quicker in the car.
Re: Where to install intake cl on this cam. [Re: galen] #2448556
02/08/18 03:45 PM
02/08/18 03:45 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
^ Being a street car I can see your point but I was unsure if the little more stroke would like it with the 264/270
Re: Where to install intake cl on this cam. [Re: Clanton] #2448567
02/08/18 04:06 PM
02/08/18 04:06 PM
Missouri
galen Offline OP
galen  Offline OP
Missouri
Thanks for the input everyone. My trans is a tci 6x. gear ratios are 2.97,2.23,1.57,1.18,1.00,0.75. Only reason I am holding off on a new cam is I am hoping to go Holley HP efi. I know that will require a matching camshaft when the time comes.
Re: Where to install intake cl on this cam. [Re: galen] #2448568
02/08/18 04:08 PM
02/08/18 04:08 PM
So. Burlington, Vt.
So. Burlington, Vt.
With 3.73's and a .75 OD an even smaller cam would be prefered for a more favorable cruise RPM, IMO.
Re: Where to install intake cl on this cam. [Re: fast68plymouth] #2448687
02/08/18 08:38 PM
02/08/18 08:38 PM
Missouri
galen Offline OP
galen  Offline OP
Missouri
Dwayne I sent you a pm.
