#2414500 - 12/06/17 09:36 PM
rally wheel trim came off but will not go on without1/4 gap
Loc: fresno
newly painted 1970 14 inch rally steel wheels mounted new tires but can not get wheel trim seated used rubber hammer but will not seat any suggestions
#2414575 - 12/07/17 01:18 AM
Re: rally wheel trim came off but will not go on without1/4 gap
[Re: hyefatman]
Loc: Lansing, MI
Do not use a hammer......you will see dents from this method. I sit on the ground and use both hands and both feet to push in place. No dents this way....
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
#2414581 - 12/07/17 03:27 AM
[Re: hyefatman]
Loc: northwest USA
Then1/4" gap is built in, that will never get smaller.
#2414642 - 12/07/17 09:40 AM
[Re: Alaskan_TA]
Loc: North Dakota
I thought, THOUGHT, that gap was for wheel weight clearance.
Wife says too many cars, liquidation coming soon......
#2414643 - 12/07/17 09:40 AM
[Re: hyefatman]
Loc: Mass
newly painted 1970 14 inch rally steel wheels mounted new tires but can not get wheel trim seated used rubber hammer but will not seat any suggestions Is this gap on the outer rim area?, if so, after you had tires mounted and BALANCED, is it perhaps the wheel weights that are holding the trim ring from seating?
#2414967 - 12/07/17 07:59 PM
[Re: hyefatman]
Loc: fresno
my 15 inch rally wheels have no gap, but you guys may be correct the inner section contacts the rim & bottoms out on the 14 inch wheel. thanks
#2415120 - 12/08/17 07:24 AM
[Re: DAYCLONA]
Loc: Caracas, Venezuela, SouthAmeri...
newly painted 1970 14 inch rally steel wheels mounted new tires but can not get wheel trim seated used rubber hammer but will not seat any suggestions Is this gap on the outer rim area?, if so, after you had tires mounted and BALANCED, is it perhaps the wheel weights that are holding the trim ring from seating? that's what initially I thought. I usually request to install weights on inside side of the wheel when as far is posible...
#2415151 - 12/08/17 08:43 AM
[Re: 70gtx440dana]
Loc: New Mexico
68 Charger 383/ AT Green/Green VT 70 Roadrunner 383/4sp Purple/Black VT
25,247 Registered Members
188,849 Topics
