Re: rally wheel trim came off but will not go on without1/4 gap
[Re: hyefatman]
#2414575
12/07/17 04:18 AM
12/07/17 04:18 AM
Posts: 3,519 Lansing, MI
70gtx440dana
Lansing, MI
Do not use a hammer......you will see dents from this method. I sit on the ground and use both hands and both feet to push in place. No dents this way....
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
[Re: Alaskan_TA]
#2414642
12/07/17 12:40 PM
12/07/17 12:40 PM
Posts: 10,696 North Dakota
6PakBee
North Dakota
I thought, THOUGHT, that gap was for wheel weight clearance.
[Re: hyefatman]
#2414643
12/07/17 12:40 PM
12/07/17 12:40 PM
Posts: 18,157 Mass
DAYCLONA
Mass
newly painted 1970 14 inch rally steel wheels mounted new tires but can not get wheel trim seated used rubber hammer but will not seat any suggestions Is this gap on the outer rim area?, if so, after you had tires mounted and BALANCED, is it perhaps the wheel weights that are holding the trim ring from seating?
[Re: DAYCLONA]
#2415120
12/08/17 10:24 AM
12/08/17 10:24 AM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
newly painted 1970 14 inch rally steel wheels mounted new tires but can not get wheel trim seated used rubber hammer but will not seat any suggestions Is this gap on the outer rim area?, if so, after you had tires mounted and BALANCED, is it perhaps the wheel weights that are holding the trim ring from seating? that's what initially I thought. I usually request to install weights on inside side of the wheel when as far is posible...
