#2414500 - 12/06/17 09:36 PM rally wheel trim came off but will not go on without1/4 gap
hyefatman Offline
Loc: fresno
newly painted 1970 14 inch rally steel wheels mounted new tires but can not get wheel trim seated used rubber hammer but will not seat any suggestions
#2414575 - 12/07/17 01:18 AM Re: rally wheel trim came off but will not go on without1/4 gap [Re: hyefatman]
70gtx440dana Offline
Loc: Lansing, MI
Do not use a hammer......you will see dents from this method. I sit on the ground and use both hands and both feet to push in place. No dents this way....
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
#2414581 - 12/07/17 03:27 AM Re: rally wheel trim came off but will not go on without1/4 gap [Re: hyefatman]
NANKET Online   work
Loc: northwest USA
Then1/4" gap is built in, that will never get smaller.
#2414593 - 12/07/17 07:03 AM Re: rally wheel trim came off but will not go on without1/4 gap [Re: hyefatman]
Alaskan_TA Offline
Fluffy Balladeer
Loc: Moredoor, PA
Yep, once the inner section contacts the rim & bottoms out, that is it.
Totally normal.
#2414642 - 12/07/17 09:40 AM Re: rally wheel trim came off but will not go on without1/4 gap [Re: Alaskan_TA]
6PakBee Offline
Loc: North Dakota
I thought, THOUGHT, that gap was for wheel weight clearance.
Wife says too many cars, liquidation coming soon......
#2414643 - 12/07/17 09:40 AM Re: rally wheel trim came off but will not go on without1/4 gap [Re: hyefatman]
DAYCLONA Offline
Loc: Mass
Is this gap on the outer rim area?, if so, after you had tires mounted and BALANCED, is it perhaps the wheel weights that are holding the trim ring from seating?
#2414967 - 12/07/17 07:59 PM Re: rally wheel trim came off but will not go on without1/4 gap [Re: hyefatman]
hyefatman Offline
Loc: fresno
my 15 inch rally wheels have no gap, but you guys may be correct the inner section contacts the rim & bottoms out on the 14 inch wheel. thanks
#2414991 - 12/07/17 08:35 PM Re: rally wheel trim came off but will not go on without1/4 gap [Re: hyefatman]
Alaskan_TA Offline
Fluffy Balladeer
Loc: Moredoor, PA
On my 1970 14" Rallye wheel car;
#2415120 - 12/08/17 07:24 AM Re: rally wheel trim came off but will not go on without1/4 gap [Re: DAYCLONA]
NachoRT74 Offline
Loc: Caracas, Venezuela, SouthAmeri...
that's what initially I thought. I usually request to install weights on inside side of the wheel when as far is posible...
#2415151 - 12/08/17 08:43 AM Re: rally wheel trim came off but will not go on without1/4 gap [Re: 70gtx440dana]
JMCFAN Offline
Loc: New Mexico
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
25,485 Registered Members
192,919 Topics
Monster Mopar Weekend @ Gateway
by 71yelladustr
09/18/18 10:58 PM
Single feed vs. dual feed carb.
by 440mopar
09/18/18 10:41 PM
Wear can you get A-Body Rear Shackle Hangers?
by Hoop
09/18/18 10:06 PM
Hallmark mystery movie Mopars
by stumpy
09/18/18 09:29 PM
