rally wheel trim came off but will not go on without1/4 gap #2414500
12/07/17 12:36 AM
12/07/17 12:36 AM
fresno
hyefatman Offline OP
fresno
newly painted 1970 14 inch rally steel wheels mounted new tires but can not get wheel trim seated used rubber hammer but will not seat any suggestions
Re: rally wheel trim came off but will not go on without1/4 gap [Re: hyefatman] #2414575
12/07/17 04:18 AM
12/07/17 04:18 AM
Lansing, MI
70gtx440dana Offline
Lansing, MI
Do not use a hammer......you will see dents from this method. I sit on the ground and use both hands and both feet to push in place. No dents this way....
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: rally wheel trim came off but will not go on without1/4 gap [Re: hyefatman] #2414581
12/07/17 06:27 AM
12/07/17 06:27 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Then1/4" gap is built in, that will never get smaller.
Re: rally wheel trim came off but will not go on without1/4 gap [Re: hyefatman] #2414593
12/07/17 10:03 AM
12/07/17 10:03 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Yep, once the inner section contacts the rim & bottoms out, that is it.
Totally normal.
Re: rally wheel trim came off but will not go on without1/4 gap [Re: Alaskan_TA] #2414642
12/07/17 12:40 PM
12/07/17 12:40 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I thought, THOUGHT, that gap was for wheel weight clearance.
Re: rally wheel trim came off but will not go on without1/4 gap [Re: hyefatman] #2414643
12/07/17 12:40 PM
12/07/17 12:40 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Is this gap on the outer rim area?, if so, after you had tires mounted and BALANCED, is it perhaps the wheel weights that are holding the trim ring from seating?
Re: rally wheel trim came off but will not go on without1/4 gap [Re: hyefatman] #2414967
12/07/17 10:59 PM
12/07/17 10:59 PM
fresno
fresno
my 15 inch rally wheels have no gap, but you guys may be correct the inner section contacts the rim & bottoms out on the 14 inch wheel. thanks
Re: rally wheel trim came off but will not go on without1/4 gap [Re: hyefatman] #2414991
12/07/17 11:35 PM
12/07/17 11:35 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
On my 1970 14" Rallye wheel car;
Re: rally wheel trim came off but will not go on without1/4 gap [Re: DAYCLONA] #2415120
12/08/17 10:24 AM
12/08/17 10:24 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
that's what initially I thought. I usually request to install weights on inside side of the wheel when as far is posible...
Re: rally wheel trim came off but will not go on without1/4 gap [Re: 70gtx440dana] #2415151
12/08/17 11:43 AM
12/08/17 11:43 AM
New Mexico
JMCFAN Offline
JMCFAN  Offline
New Mexico
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
