Re: Can you ID this aftermarket 727 torque conveter part number?
[Re: Furious440]
#2410205
11/28/17 05:28 PM
11/28/17 05:28 PM
Posts: 25,836 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Is the marking stamped into the metal or written/stenciled?
[Re: Furious440]
#2410907
11/29/17 08:10 PM
11/29/17 08:10 PM
John_Kunkel
Rio Linda, CA
The stampings are pretty much useless for identifying the converter. Diameter and weights give a clue but that's all.
A "stock" '71 440 would have no weights on the converter face but could have thin weights on the periphery.
[Re: Furious440]
#2411359
11/30/17 04:48 PM
11/30/17 04:48 PM
John_Kunkel
Rio Linda, CA
with two square weights on the face (engine side) that measure 3/4" x 1-1/4" x 1/8". As I stated, a pre-'73 440 should have no external balance weights on the converter. Either the forged crank has been replaced with a cast or the weighted converter was installed on a forged crank by mistake.
[Re: Furious440]
#2412337
12/02/17 07:06 PM
12/02/17 07:06 PM
John_Kunkel
Rio Linda, CA
The "heavy rod" motor is an exception but the weights you describe are way more than that motor needs (about twice as much).
