Can you ID this aftermarket 727 torque conveter part number? #2409962
11/28/17 02:07 AM
11/28/17 02:07 AM
Western US
Furious440 Offline OP
Western US
I pulled the stock 440 engine from my 1971 Fury. The transmission was rebuilt by the previous owner and the torque converter replaced.
The only markings on the torque converter are: 8554 1
Does anyone have any ideas? A Google search turned up nothing.
Thank you in advance to anyone who replies.
Re: Can you ID this aftermarket 727 torque conveter part number? [Re: Furious440] #2410205
11/28/17 05:28 PM
11/28/17 05:28 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Is the marking stamped into the metal or written/stenciled?
Re: Can you ID this aftermarket 727 torque conveter part number? [Re: John_Kunkel] #2410444
11/29/17 12:23 AM
11/29/17 12:23 AM
Western US
Western US
The markings are stamped. Other than that and the two weights there is nothing else on the converter.
Re: Can you ID this aftermarket 727 torque conveter part number? [Re: Furious440] #2410907
11/29/17 08:10 PM
11/29/17 08:10 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The stampings are pretty much useless for identifying the converter. Diameter and weights give a clue but that's all.
A "stock" '71 440 would have no weights on the converter face but could have thin weights on the periphery.
Re: Can you ID this aftermarket 727 torque conveter part number? [Re: John_Kunkel] #2411052
11/30/17 12:09 AM
11/30/17 12:09 AM
Western US
Western US
Thank you for the info.
I forgot to mention that it is an all numbers matching 440 HP engine & trans. The torque converter is a 12", 24 spline, with I think narrow ring gear (not sure), with two square weights on the face (engine side) that measure 3/4" x 1-1/4" x 1/8".
I looked at the Transtar catalog with no match.
Re: Can you ID this aftermarket 727 torque conveter part number? [Re: Furious440] #2411082
11/30/17 01:25 AM
11/30/17 01:25 AM
NC, USA
davenc Offline
davenc  Offline
NC, USA
Does the torque convertor have a drain plug?
Re: Can you ID this aftermarket 727 torque conveter part number? [Re: Furious440] #2411359
11/30/17 04:48 PM
11/30/17 04:48 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
As I stated, a pre-'73 440 should have no external balance weights on the converter.
Either the forged crank has been replaced with a cast or the weighted converter was installed on a forged crank by mistake.
Re: Can you ID this aftermarket 727 torque conveter part number? [Re: John_Kunkel] #2412039
12/02/17 12:23 AM
12/02/17 12:23 AM
Western US
Western US
shockWow! Okay...I'm pretty sure it does have a drain plug. I will have to go back to the shop and check.
It's my understanding that the crank is original in this E86 motor as are the Six Pack rods. The pistons are new TRW L2355F. The rebuild papers say the assembly was balanced.
Re: Can you ID this aftermarket 727 torque conveter part number? [Re: Furious440] #2412337
12/02/17 07:06 PM
12/02/17 07:06 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The "heavy rod" motor is an exception but the weights you describe are way more than that motor needs (about twice as much).
Re: Can you ID this aftermarket 727 torque conveter part number? [Re: John_Kunkel] #2412516
12/03/17 12:36 AM
12/03/17 12:36 AM
Western US
Western US
Well, I have confirmed the rods, steel forged crankshaft and the thin or "skinny" balancer on the motor.
I just wish I knew what torque converter the tranny shop put in...
