#2409273 - 11/26/17 05:58 PM Antenna masts
fastmark Offline
Loc: Abilene, Texas
I’ve got two types in my parts stash. Looks like most got the 60” telescoping mast. When did they use the solid mast?
#2409277 - 11/26/17 06:08 PM Re: Antenna masts [Re: fastmark]
Alaskan_TA Offline
Fluffy Balladeer
Loc: Moredoor, PA
Easy rhyme to remember;
The solid mast was new
For 1972
#2409301 - 11/26/17 06:47 PM Re: Antenna masts [Re: fastmark]
fastmark Offline
Loc: Abilene, Texas
#2409455 - 11/26/17 10:50 PM Re: Antenna masts [Re: fastmark]
a12rag Offline
Loc: Calgary, Alberta Canada
Not sure where I got it, but I have a "4" piece telescoping antenna . . . it reaches the stratoshpere . . . ha ha ha, not sure what it would have come on, or even where I ended up picking it up . . . it is the screw in type, like the single mast . . .
#2409514 - 11/27/17 07:43 AM Re: Antenna masts [Re: fastmark]
fastmark Offline
Loc: Abilene, Texas
Most of the telescoping ones have laying around have a longer threaded part on them. I’m finishing up a 70 Challenger and it will not accept the longer threads. It won’t screw down flush. I’m sure the base and antenna have been changed. I have several solid masts and they all have shorter threads. That is all that will fit this one.
#2409725 - 11/27/17 03:43 PM Re: Antenna masts [Re: Alaskan_TA]
formula_s Offline
Loc: North Pole,New York
For 1972
How would a 70 PM43 have had a fixed mast antenna? .Car was bought new in 6-70 R11 radio.
Edited by formula_s (11/27/17 03:45 PM)
#2409806 - 11/27/17 06:28 PM Re: Antenna masts [Re: a12rag]
a12rag Offline
Here are pics of the big long 4 piece antenna . . . 76" total length when extended !
#2410084 - 11/28/17 09:53 AM Re: Antenna masts [Re: fastmark]
davesmopars Online   content
Loc: cheshire, ct
Solid mast started before 72 are you 100% sure on this?
so all A Bodies before 72 are telescoping
#2410259 - 11/28/17 04:22 PM Re: Antenna masts [Re: fastmark]
a12rag Offline
Think that 69 or 70 started the single solid mast antenna . . .
#2410265 - 11/28/17 04:40 PM Re: Antenna masts [Re: fastmark]
Alaskan_TA Offline
Fluffy Balladeer
Loc: Moredoor, PA
I can beat the topic to death if you like? I'd have to find my file on it.........
#2410319 - 11/28/17 06:26 PM Re: Antenna masts [Re: a12rag]
BlueRacer69 Offline
Loc: Michigan
Not 69 cars. Maybe it started sometime in 70 or 71 but not in 69.
#2410370 - 11/28/17 07:51 PM Re: Antenna masts [Re: fastmark]
fastmark Offline
Loc: Abilene, Texas
Did fm cars get the same one as am radio.
#2410380 - 11/28/17 08:02 PM Re: Antenna masts [Re: fastmark]
Alaskan_TA Offline
Fluffy Balladeer
Loc: Moredoor, PA
I have 1970 AM, AM / FM & AM 8 track cars here. All telescopic.
Then, later on - the 1972 model year began..........
#2410442 - 11/28/17 09:21 PM Re: Antenna masts [Re: formula_s]
formula_s Offline
For 1972
So can you give me a plausible reason for the above??
#2410570 - 11/29/17 05:54 AM Re: Antenna masts [Re: fastmark]
Alaskan_TA Offline
Fluffy Balladeer
Loc: Moredoor, PA
They can be swapped out in a few minutes if one was broken, stolen or damaged.
Check your owners manual, the part about adjusting the antenna. ;-)
#2412394 - 12/02/17 05:55 PM Re: Antenna masts [Re: fastmark]
Alaskan_TA Offline
Fluffy Balladeer
Loc: Moredoor, PA
From the 1970 FSM;
#2412396 - 12/02/17 05:56 PM Re: Antenna masts [Re: fastmark]
Alaskan_TA Offline
Fluffy Balladeer
Loc: Moredoor, PA
Link to the 1972 Service Highlights page about the new for '72 antenna;
http://www.hamtramck-historical.com/images/serviceHighlights/1972/1972%20sh%20p33.jpg
#2412397 - 12/02/17 05:58 PM Re: Antenna masts [Re: fastmark]
Alaskan_TA Offline
Fluffy Balladeer
Loc: Moredoor, PA
From a 1970 owners manual;
#2412620 - 12/03/17 08:43 AM Re: Antenna masts [Re: fastmark]
Tempest Offline
Loc: Nashville, Tennessee
I have a 50,000 mile '69 RR with AM radio and telescoping one.
#2418123 - 12/13/17 04:53 PM Re: Antenna masts [Re: Tempest]
Kowal Offline
Loc: Charlotte, NC
Mopar dealers sold an extra height, telescoping antenna, for areas with poor radio reception. For the post above that has the extra long piece, that is probably what it is. A little thicker as well
'69 Hemi Charger 500
'69 GTX
P.J. O'Rouke: "The old car ran perfectly, right up until it didn't."
25,622 Registered Members
195,482 Topics
Paging OZ
by dart4forte
12/09/18 10:22 PM
72 Scamp
by Neil
12/09/18 09:50 PM
ROLLER CAM LOW LIFT FLOW HEADS
by A/MP
12/09/18 09:42 PM
76 d100 gas tank filler neck replacement
by 76_d100
12/09/18 09:22 PM
