Re: Antenna masts
[Re: Alaskan_TA]
#2409725
11/27/17 06:43 PM
11/27/17 06:43 PM
Posts: 4,996 North Pole,New York
formula_s
North Pole,New York
Easy rhyme to remember;
The solid mast was new
For 1972 How would a 70 PM43 have had a fixed mast antenna? .Car was bought new in 6-70 R11 radio.
Re: Antenna masts
[Re: a12rag]
#2409806
11/27/17 09:28 PM
11/27/17 09:28 PM
Posts: 2,915 Calgary, Alberta Canada
a12rag
Not sure where I got it, but I have a "4" piece telescoping antenna . . . it reaches the stratoshpere . . . ha ha ha, not sure what it would have come on, or even where I ended up picking it up . . . it is the screw in type, like the single mast . . . Here are pics of the big long 4 piece antenna . . . 76" total length when extended !
Re: Antenna masts
[Re: fastmark]
#2410084
11/28/17 12:53 PM
11/28/17 12:53 PM
Posts: 3,392 cheshire, ct
davesmopars
cheshire, ct
Solid mast started before 72 are you 100% sure on this? so all A Bodies before 72 are telescoping
Keeper of the 440 M code Cuda registry mcodecuda@yahoo.com
Re: Antenna masts
[Re: a12rag]
#2410319
11/28/17 09:26 PM
11/28/17 09:26 PM
Posts: 727 Michigan
BlueRacer69
Think that 69 or 70 started the single solid mast antenna . . . Not 69 cars. Maybe it started sometime in 70 or 71 but not in 69.
Re: Antenna masts
[Re: formula_s]
#2410442
11/29/17 12:21 AM
11/29/17 12:21 AM
formula_s
North Pole,New York
For 1972 How would a 70 PM43 have had a fixed mast antenna? .Car was bought new in 6-70 R11 radio. So can you give me a plausible reason for the above??
Re: Antenna masts
[Re: Tempest]
#2418123
12/13/17 07:53 PM
12/13/17 07:53 PM
Posts: 531 Charlotte, NC
Kowal
Charlotte, NC
Mopar dealers sold an extra height, telescoping antenna, for areas with poor radio reception. For the post above that has the extra long piece, that is probably what it is. A little thicker as well
'69 Hemi Charger 500, ‘70 U code Challenger R/T (These and a bunch others at www.dkowal426.com) P.J. O'Rouke: "The old car ran perfectly, right up until it didn't."
