Antenna masts #2409273
11/26/17 08:58 PM
11/26/17 08:58 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
I’ve got two types in my parts stash. Looks like most got the 60” telescoping mast. When did they use the solid mast?
Re: Antenna masts [Re: fastmark] #2409277
11/26/17 09:08 PM
11/26/17 09:08 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Easy rhyme to remember;
The solid mast was new
For 1972
Re: Antenna masts [Re: fastmark] #2409301
11/26/17 09:47 PM
11/26/17 09:47 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Re: Antenna masts [Re: fastmark] #2409455
11/27/17 01:50 AM
11/27/17 01:50 AM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Not sure where I got it, but I have a "4" piece telescoping antenna . . . it reaches the stratoshpere . . . ha ha ha, not sure what it would have come on, or even where I ended up picking it up . . . it is the screw in type, like the single mast . . .
Re: Antenna masts [Re: fastmark] #2409514
11/27/17 10:43 AM
11/27/17 10:43 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Most of the telescoping ones have laying around have a longer threaded part on them. I’m finishing up a 70 Challenger and it will not accept the longer threads. It won’t screw down flush. I’m sure the base and antenna have been changed. I have several solid masts and they all have shorter threads. That is all that will fit this one.
Re: Antenna masts [Re: Alaskan_TA] #2409725
11/27/17 06:43 PM
11/27/17 06:43 PM
North Pole,New York
formula_s Offline
formula_s  Offline
North Pole,New York
For 1972
How would a 70 PM43 have had a fixed mast antenna? .Car was bought new in 6-70 R11 radio.
Re: Antenna masts [Re: a12rag] #2409806
11/27/17 09:28 PM
11/27/17 09:28 PM
a12rag Offline
a12rag  Offline
Here are pics of the big long 4 piece antenna . . . 76" total length when extended !
Re: Antenna masts [Re: fastmark] #2410084
11/28/17 12:53 PM
11/28/17 12:53 PM
cheshire, ct
davesmopars Offline
davesmopars  Offline
cheshire, ct
Solid mast started before 72 are you 100% sure on this?
so all A Bodies before 72 are telescoping
Keeper of the 440 M code Cuda registry
mcodecuda@yahoo.com
Re: Antenna masts [Re: fastmark] #2410259
11/28/17 07:22 PM
11/28/17 07:22 PM
a12rag Offline
a12rag  Offline
Think that 69 or 70 started the single solid mast antenna . . .
Re: Antenna masts [Re: fastmark] #2410265
11/28/17 07:40 PM
11/28/17 07:40 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I can beat the topic to death if you like? I'd have to find my file on it.........
Re: Antenna masts [Re: a12rag] #2410319
11/28/17 09:26 PM
11/28/17 09:26 PM
BlueRacer69 Offline
BlueRacer69  Offline
Not 69 cars. Maybe it started sometime in 70 or 71 but not in 69.
Re: Antenna masts [Re: fastmark] #2410370
11/28/17 10:51 PM
11/28/17 10:51 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Did fm cars get the same one as am radio.
Re: Antenna masts [Re: fastmark] #2410380
11/28/17 11:02 PM
11/28/17 11:02 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I have 1970 AM, AM / FM & AM 8 track cars here. All telescopic.
Then, later on - the 1972 model year began..........
Re: Antenna masts [Re: formula_s] #2410442
11/29/17 12:21 AM
11/29/17 12:21 AM
North Pole,New York
formula_s Offline
formula_s  Offline
North Pole,New York
For 1972
So can you give me a plausible reason for the above??
Re: Antenna masts [Re: fastmark] #2410570
11/29/17 08:54 AM
11/29/17 08:54 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
They can be swapped out in a few minutes if one was broken, stolen or damaged.
Check your owners manual, the part about adjusting the antenna. ;-)
Re: Antenna masts [Re: fastmark] #2412394
12/02/17 08:55 PM
12/02/17 08:55 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
From the 1970 FSM;
Re: Antenna masts [Re: fastmark] #2412396
12/02/17 08:56 PM
12/02/17 08:56 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Link to the 1972 Service Highlights page about the new for '72 antenna;
http://www.hamtramck-historical.com/images/serviceHighlights/1972/1972%20sh%20p33.jpg
Re: Antenna masts [Re: fastmark] #2412397
12/02/17 08:58 PM
12/02/17 08:58 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
From a 1970 owners manual;
Re: Antenna masts [Re: fastmark] #2412620
12/03/17 11:43 AM
12/03/17 11:43 AM
Nashville, Tennessee
Tempest Offline
Tempest  Offline
I have a 50,000 mile '69 RR with AM radio and telescoping one.
Re: Antenna masts [Re: Tempest] #2418123
12/13/17 07:53 PM
12/13/17 07:53 PM
Charlotte, NC
Kowal Offline
Kowal  Offline
Charlotte, NC
Mopar dealers sold an extra height, telescoping antenna, for areas with poor radio reception. For the post above that has the extra long piece, that is probably what it is. A little thicker as well
'69 Hemi Charger 500, ‘70 U code Challenger R/T
(These and a bunch others at www.dkowal426.com)
P.J. O'Rouke: "The old car ran perfectly, right up until it didn't."
