Transmission help
#240394
03/01/09 09:33 PM
03/01/09 09:33 PM
Posts: 684 Colorado
swingers_rock
super gas
super gas
Colorado
Hi everyone, I have been having some transmission troubles and was wondering if anyone could point me out in the right direction on what could be wrong. My transmission is very hard to put into gear. You have to rev it in N or P then put it in D to get it going. But once its in gear it drives normal. I just replaced the torque converter to a PTC 9.5" and it still does not want to go into gear. The fluid level is wear it should be. Could the line pressure be a cause of this or?? Thanks guys!
Re: Transmission help
[Re: swingers_rock]
#240395
03/01/09 09:59 PM
03/01/09 09:59 PM
Posts: 32,971 Grand Prairie,Texas
stumpy
Grand Prairie,Texas
Does this happen first time you start the car after it sits for a while. If it is then let it idle in neutral for a few seconds before putting it in gear.It is somewaht normal and is caused tby the fluid draining back. Mopars trams don't pump fluid in park but do in neutral.
[Re: swingers_rock]
#240397
03/02/09 02:48 AM
03/02/09 02:48 AM
RapidRobert
Hello Ori, it's been awhile. What Stumpy said, let it idle for a minute or so in NEUTRAL then see if you're good. Dont overfill it, it is not needing more fluid.
[Re: swingers_rock]
#240398
03/02/09 09:53 AM
03/02/09 09:53 AM
Wonder if the pump is weak? Sounds like it was acting this way before the new convertor?
[Re: swingers_rock]
#240402
03/02/09 05:06 PM
03/02/09 05:06 PM
Posts: 25,926 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Does it have trouble going into Reverse too or just forward gears?
If it goes into Reverse OK but lags in the forward gears the problem is in the rear clutch, if it lags in both it is a pressure problem (worn pump, internal leakage, clogged filter, etc)
