Hi everyone, I have been having some transmission troubles and was wondering if anyone could point me out in the right direction on what could be wrong.
My transmission is very hard to put into gear. You have to rev it in N or P then put it in D to get it going. But once its in gear it drives normal. I just replaced the torque converter to a PTC 9.5" and it still does not want to go into gear. The fluid level is wear it should be. Could the line pressure be a cause of this or??
Thanks guys!
