Transmission help #240394
03/01/09 09:33 PM
03/01/09 09:33 PM
Colorado
swingers_rock Offline OP
super gas
super gas
Colorado
Hi everyone, I have been having some transmission troubles and was wondering if anyone could point me out in the right direction on what could be wrong.
My transmission is very hard to put into gear. You have to rev it in N or P then put it in D to get it going. But once its in gear it drives normal. I just replaced the torque converter to a PTC 9.5" and it still does not want to go into gear. The fluid level is wear it should be. Could the line pressure be a cause of this or??
Thanks guys!
Re: Transmission help [Re: swingers_rock] #240395
03/01/09 09:59 PM
03/01/09 09:59 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Does this happen first time you start the car after it sits for a while. If it is then let it idle in neutral for a few seconds before putting it in gear.It is somewaht normal and is caused tby the fluid draining back. Mopars trams don't pump fluid in park but do in neutral.
Re: Transmission help [Re: stumpy] #240396
03/02/09 01:36 AM
03/02/09 01:36 AM
Colorado
super gas
super gas
Colorado
It can happen at anytime. Hot or cold. And sometimes it doesnt even go into gear when im trying to pull it out of the garage or something.
Could i overfill it and see if that helps? Maybe a valve is stuck in the valve body or ??
Re: Transmission help [Re: swingers_rock] #240397
03/02/09 02:48 AM
03/02/09 02:48 AM
Hello Ori, it's been awhile. What Stumpy said, let it idle for a minute or so in NEUTRAL then see if you're good. Dont overfill it, it is not needing more fluid.
Re: Transmission help [Re: swingers_rock] #240398
03/02/09 09:53 AM
03/02/09 09:53 AM
Wonder if the pump is weak? Sounds like it was acting this way before the new convertor?
Re: Transmission help [Re: ] #240399
03/02/09 10:40 AM
03/02/09 10:40 AM
Colorado
super gas
super gas
Colorado
Yes it was acting this way before the new converter. And it doesnt matter how long i let it sit in N sometimes it does/doesnt want to go into gear.
Re: Transmission help [Re: swingers_rock] #240400
03/02/09 10:51 AM
03/02/09 10:51 AM
Grand Prairie,Texas
Grand Prairie,Texas
Sounds like it might be rebuild time.
Re: Transmission help [Re: swingers_rock] #240401
03/02/09 10:51 AM
03/02/09 10:51 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
It needs a freshen up as all or most of the seals are leaking. you could try a bottle of Lucus trans fix but it won't do nothing for the steel sealing rings!
Re: Transmission help [Re: swingers_rock] #240402
03/02/09 05:06 PM
03/02/09 05:06 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Does it have trouble going into Reverse too or just forward gears?
If it goes into Reverse OK but lags in the forward gears the problem is in the rear clutch, if it lags in both it is a pressure problem (worn pump, internal leakage, clogged filter, etc)
