First outing with junkyard 5.7 = Win!!
#2395826
10/31/17 01:30 AM
10/31/17 01:30 AM
Posts: 1,035 Missouri U.S.A.
71yelladustr
Missouri U.S.A.
Did a little racing at MoKan yesterday with our 225k mile junkyard hemi resulting in shattering previous class ET and MPH records along with getting the win. It went 6.83 @98.3 mph in the 1/8 with a VERY basic engine combo in our 3150lb Ex cab Dakota. The lil hemi is nothing more than a stock 04 shortblock, wearing a pair of lightly touched up eagle heads, comp 273 cam, PAC springs, Ritter intake w/ 4150 carb on 93 pump gas. This thing is a monster for what it is and put our previous 360 magnum power plant to shame. I must add that the 360 was pretty stout having almost 11/1 compression, ported 2.02 valve magnum heads, 250@.050 SFT cam and Indy intake with the same carb. The 360 could only muster 7.18 @ 95mph. For those those that are on the fence about going gen III hemi, this should help sway some to take the leap. Sure glad we did!
392 gen III hemi on E-85 727 trans Dana 60 10.02@134
Re: First outing with junkyard 5.7 = Win!!
[Re: 71yelladustr]
#2395902
10/31/17 09:19 AM
10/31/17 09:19 AM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
They do run very well, the more people run these the better
Truth has no agenda, but those with an agenda make their own truth. Some of us are so open minded they only see their View
[Re: superchuck]
#2395982
10/31/17 12:22 PM
10/31/17 12:22 PM
71yelladustr
Missouri U.S.A.
MSD hemi 6 ignition with 06-08 factory coils. Shifting engine at 6900 rpms.
[Re: 71yelladustr]
#2396045
10/31/17 01:59 PM
10/31/17 01:59 PM
Posts: 153 MI, USA
moparmitch
MI, USA
Any decent guess at your compression?
What kind of timing are you running?
Totally stock valve-train?
Still pulling to 6900?
Thanks for sharing!
[Re: moparmitch]
#2396111
10/31/17 03:47 PM
10/31/17 03:47 PM
71yelladustr
Missouri U.S.A.
Stock rockers and shafts. It does have Comp hardened 5/16 pushrods. I would have used the stock ones but didn't have any from the Eagle head donor engine. Compression is in the neighborhood of 12/1. Stock head gaskets. This thing revs very quickly. It's like a 2 cycle. You have to be very careful in the burnout not to turn it over 7000. Yeah it's still pulling like a fright train at 6900. We did stick a used 6.1 oil pump in it for a pressure increase. I think it will live for quite a while under 7k. I have not messed with the timing at all yet. Timing is as delivered from MSD. Doesn't show any signs of detonating at 24* total. I'm gonna put my Sullens E-85 carb on it and see what it does. I think there is a tenth or maybe 2 on the table by just making the switch to E.
[Re: 71yelladustr]
#2396158
10/31/17 04:56 PM
10/31/17 04:56 PM
71yelladustr
Missouri U.S.A.
94 ex cab SB
[Re: 71yelladustr]
#2396203
10/31/17 06:20 PM
10/31/17 06:20 PM
Triple Threat
Renton Washington
That's awesome. Always wondered what a combo like this would run!
[Re: 71yelladustr]
#2396350
10/31/17 11:12 PM
10/31/17 11:12 PM
71yelladustr
Missouri U.S.A.
Thanks Dustin! I've been following your build as well. I'm wanting to replace the 440 in my Duster with something similar to your setup. I want something that is low maintenance and hauls the mail naturally aspirated. Your car is very impressive!
[Re: cudaman1969]
#2396502
11/01/17 08:32 AM
11/01/17 08:32 AM
ric3xrt
Trumbauersville PA
What pistons to get over 10 comp The stock Pre 09 pistons yield monster compression with the Eagle heads Did you open up the top ring Gap at all?
[Re: 71yelladustr]
#2396526
11/01/17 10:08 AM
11/01/17 10:08 AM
Posts: 8,248 fredericksburg,va
cudaman1969
fredericksburg,va
Refresh my memory, what years for Eagle heads? I guess I'll be looking for a set.
[Re: cudaman1969]
#2396553
11/01/17 10:55 AM
11/01/17 10:55 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
Refresh my memory, what years for Eagle heads? I guess I'll be looking for a set. 09 and newer 5.7 heads
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: moparmitch]
#2396679
11/01/17 02:24 PM
11/01/17 02:24 PM
71yelladustr
Missouri U.S.A.
Comp 112-502-11 cam. Known as 273 xfi cam. .550/.547 lift. Clearance is tight. Not much room for anything bigger without intake valve notches on the pistons. Tried a 229/235 Drag pack cam but would not clear factory 08 and down pistons. Intake valves were contacting pistons.
