Page 1 of 3 1 2 3
First outing with junkyard 5.7 = Win!! #2395826
10/31/17 01:30 AM
10/31/17 01:30 AM
Missouri U.S.A.
71yelladustr Offline OP
Missouri U.S.A.
Did a little racing at MoKan yesterday with our 225k mile junkyard hemi resulting in shattering previous class ET and MPH records along with getting the win. It went 6.83 @98.3 mph in the 1/8 with a VERY basic engine combo in our 3150lb Ex cab Dakota. The lil hemi is nothing more than a stock 04 shortblock, wearing a pair of lightly touched up eagle heads, comp 273 cam, PAC springs, Ritter intake w/ 4150 carb on 93 pump gas. This thing is a monster for what it is and put our previous 360 magnum power plant to shame. I must add that the 360 was pretty stout having almost 11/1 compression, ported 2.02 valve magnum heads, 250@.050 SFT cam and Indy intake with the same carb. The 360 could only muster 7.18 @ 95mph. For those those that are on the fence about going gen III hemi, this should help sway some to take the leap. Sure glad we did!
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: First outing with junkyard 5.7 = Win!! [Re: 71yelladustr] #2395898
10/31/17 09:05 AM
10/31/17 09:05 AM
MI, USA
moparmitch Offline
moparmitch  Offline
MI, USA
This is pretty cool...I've considered a similar engine to put in a 2700 LB race weight car.
What rpm do you shift at?
Re: First outing with junkyard 5.7 = Win!! [Re: 71yelladustr] #2395902
10/31/17 09:19 AM
10/31/17 09:19 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
They do run very well, the more people run these the better
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: First outing with junkyard 5.7 = Win!! [Re: 71yelladustr] #2395904
10/31/17 09:25 AM
10/31/17 09:25 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Very nice!!! Love it
Re: First outing with junkyard 5.7 = Win!! [Re: 71yelladustr] #2395941
10/31/17 11:03 AM
10/31/17 11:03 AM
midwest
superchuck Offline
On thin ice
superchuck  Offline
On thin ice
midwest
What are you using for an ignition system? Crank trigger to fire the coils?
Re: First outing with junkyard 5.7 = Win!! [Re: superchuck] #2395982
10/31/17 12:22 PM
10/31/17 12:22 PM
Missouri U.S.A.
Missouri U.S.A.
MSD hemi 6 ignition with 06-08 factory coils. Shifting engine at 6900 rpms.
10.02@134
Re: First outing with junkyard 5.7 = Win!! [Re: 71yelladustr] #2396038
10/31/17 01:38 PM
10/31/17 01:38 PM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
Nice results. I have some Eagle heads sitting on the shelf with Pac springs . I was saving them but I might put them on my stock short block.
What thickness head gasket did you use?
Re: First outing with junkyard 5.7 = Win!! [Re: 71yelladustr] #2396045
10/31/17 01:59 PM
10/31/17 01:59 PM
MI, USA
moparmitch Offline
moparmitch  Offline
MI, USA
Any decent guess at your compression?
What kind of timing are you running?
Totally stock valve-train?
Still pulling to 6900?
Thanks for sharing!
Re: First outing with junkyard 5.7 = Win!! [Re: moparmitch] #2396111
10/31/17 03:47 PM
10/31/17 03:47 PM
Missouri U.S.A.
Missouri U.S.A.
Stock rockers and shafts. It does have Comp hardened 5/16 pushrods. I would have used the stock ones but didn't have any from the Eagle head donor engine. Compression is in the neighborhood of 12/1. Stock head gaskets. This thing revs very quickly. It's like a 2 cycle. You have to be very careful in the burnout not to turn it over 7000. Yeah it's still pulling like a fright train at 6900. We did stick a used 6.1 oil pump in it for a pressure increase. I think it will live for quite a while under 7k. I have not messed with the timing at all yet. Timing is as delivered from MSD. Doesn't show any signs of detonating at 24* total. I'm gonna put my Sullens E-85 carb on it and see what it does. I think there is a tenth or maybe 2 on the table by just making the switch to E.
10.02@134
Re: First outing with junkyard 5.7 = Win!! [Re: 71yelladustr] #2396135
10/31/17 04:18 PM
10/31/17 04:18 PM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
Nice
What year dakota?
Re: First outing with junkyard 5.7 = Win!! [Re: 71yelladustr] #2396158
10/31/17 04:56 PM
10/31/17 04:56 PM
Missouri U.S.A.
Missouri U.S.A.
94 ex cab SB
10.02@134
Re: First outing with junkyard 5.7 = Win!! [Re: 71yelladustr] #2396203
10/31/17 06:20 PM
10/31/17 06:20 PM
Renton Washington
Triple Threat Offline
Renton Washington
That's awesome. Always wondered what a combo like this would run!
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: First outing with junkyard 5.7 = Win!! [Re: 71yelladustr] #2396350
10/31/17 11:12 PM
10/31/17 11:12 PM
Missouri U.S.A.
Missouri U.S.A.
Thanks Dustin! I've been following your build as well. I'm wanting to replace the 440 in my Duster with something similar to your setup. I want something that is low maintenance and hauls the mail naturally aspirated. Your car is very impressive!
10.02@134
Re: First outing with junkyard 5.7 = Win!! [Re: 71yelladustr] #2396379
10/31/17 11:48 PM
10/31/17 11:48 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
What pistons to get over 10 comp
Re: First outing with junkyard 5.7 = Win!! [Re: cudaman1969] #2396502
11/01/17 08:32 AM
11/01/17 08:32 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
The stock Pre 09 pistons yield monster compression with the Eagle heads
Did you open up the top ring Gap at all?
Re: First outing with junkyard 5.7 = Win!! [Re: 71yelladustr] #2396522
11/01/17 10:02 AM
11/01/17 10:02 AM
Missouri U.S.A.
Missouri U.S.A.
Didn't touch the rings
10.02@134
Re: First outing with junkyard 5.7 = Win!! [Re: 71yelladustr] #2396526
11/01/17 10:08 AM
11/01/17 10:08 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Refresh my memory, what years for Eagle heads? I guess I'll be looking for a set.
Re: First outing with junkyard 5.7 = Win!! [Re: cudaman1969] #2396553
11/01/17 10:55 AM
11/01/17 10:55 AM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
09 and newer 5.7 heads
Re: First outing with junkyard 5.7 = Win!! [Re: 71yelladustr] #2396632
11/01/17 01:21 PM
11/01/17 01:21 PM
MI, USA
moparmitch Offline
moparmitch  Offline
MI, USA
How much cam lift at the valves and what kind of clearance to piston.
This is a shelf cam?
Re: First outing with junkyard 5.7 = Win!! [Re: moparmitch] #2396679
11/01/17 02:24 PM
11/01/17 02:24 PM
Missouri U.S.A.
Missouri U.S.A.
Comp 112-502-11 cam. Known as 273 xfi cam. .550/.547 lift. Clearance is tight. Not much room for anything bigger without intake valve notches on the pistons. Tried a 229/235 Drag pack cam but would not clear factory 08 and down pistons. Intake valves were contacting pistons.
10.02@134
Page 1 of 3 1 2 3
