Page 1 of 3 1 2 3 >
#2395826 - 10/30/17 11:30 PM First outing with junkyard 5.7 = Win!!
71yelladustr Offline
Loc: Missouri U.S.A.
Did a little racing at MoKan yesterday with our 225k mile junkyard hemi resulting in shattering previous class ET and MPH records along with getting the win. It went 6.83 @98.3 mph in the 1/8 with a VERY basic engine combo in our 3150lb Ex cab Dakota. The lil hemi is nothing more than a stock 04 shortblock, wearing a pair of lightly touched up eagle heads, comp 273 cam, PAC springs, Ritter intake w/ 4150 carb on 93 pump gas. This thing is a monster for what it is and put our previous 360 magnum power plant to shame. I must add that the 360 was pretty stout having almost 11/1 compression, ported 2.02 valve magnum heads, 250@.050 SFT cam and Indy intake with the same carb. The 360 could only muster 7.18 @ 95mph. For those those that are on the fence about going gen III hemi, this should help sway some to take the leap. Sure glad we did!
Edited by 71yelladustr (03/15/18 11:02 PM)
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
#2395898 - 10/31/17 07:05 AM Re: First outing with junkyard 5.7 = Win!! [Re: 71yelladustr]
moparmitch Offline
Loc: MI, USA
This is pretty cool...I've considered a similar engine to put in a 2700 LB race weight car.
What rpm do you shift at?
#2395902 - 10/31/17 07:19 AM Re: First outing with junkyard 5.7 = Win!! [Re: 71yelladustr]
ric3xrt Offline
Loc: Trumbauersville PA
They do run very well, the more people run these the better
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
#2395904 - 10/31/17 07:25 AM Re: First outing with junkyard 5.7 = Win!! [Re: 71yelladustr]
sixpackgut Offline
Drag Week Mod Champion
Loc: Charleston
Very nice!!! Love it
#2395941 - 10/31/17 09:03 AM Re: First outing with junkyard 5.7 = Win!! [Re: 71yelladustr]
superchuck Offline
On thin ice
Loc: midwest
What are you using for an ignition system? Crank trigger to fire the coils?
#2395982 - 10/31/17 10:22 AM Re: First outing with junkyard 5.7 = Win!! [Re: superchuck]
MSD hemi 6 ignition with 06-08 factory coils. Shifting engine at 6900 rpms.
10.02@134
#2396038 - 10/31/17 11:38 AM Re: First outing with junkyard 5.7 = Win!! [Re: 71yelladustr]
RTSE4ME Offline
Loc: MD
Nice results. I have some Eagle heads sitting on the shelf with Pac springs . I was saving them but I might put them on my stock short block.
What thickness head gasket did you use?
#2396045 - 10/31/17 11:59 AM Re: First outing with junkyard 5.7 = Win!! [Re: 71yelladustr]
moparmitch Offline
Loc: MI, USA
Any decent guess at your compression?
What kind of timing are you running?
Totally stock valve-train?
Still pulling to 6900?
Thanks for sharing!
Edited by moparmitch (10/31/17 12:10 PM)
#2396111 - 10/31/17 01:47 PM Re: First outing with junkyard 5.7 = Win!! [Re: moparmitch]
Stock rockers and shafts. It does have Comp hardened 5/16 pushrods. I would have used the stock ones but didn't have any from the Eagle head donor engine. Compression is in the neighborhood of 12/1. Stock head gaskets. This thing revs very quickly. It's like a 2 cycle. You have to be very careful in the burnout not to turn it over 7000. Yeah it's still pulling like a fright train at 6900. We did stick a used 6.1 oil pump in it for a pressure increase. I think it will live for quite a while under 7k. I have not messed with the timing at all yet. Timing is as delivered from MSD. Doesn't show any signs of detonating at 24* total. I'm gonna put my Sullens E-85 carb on it and see what it does. I think there is a tenth or maybe 2 on the table by just making the switch to E.
Edited by 71yelladustr (10/31/17 02:04 PM)
10.02@134
#2396135 - 10/31/17 02:18 PM Re: First outing with junkyard 5.7 = Win!! [Re: 71yelladustr]
A990 Offline
Loc: 541 slobovia
Nice
What year dakota?
#2396158 - 10/31/17 02:56 PM Re: First outing with junkyard 5.7 = Win!! [Re: 71yelladustr]
94 ex cab SB
Edited by 71yelladustr (10/31/17 03:04 PM)
10.02@134
#2396203 - 10/31/17 04:20 PM Re: First outing with junkyard 5.7 = Win!! [Re: 71yelladustr]
Triple Threat Offline
Loc: Renton Washington
That's awesome. Always wondered what a combo like this would run!
-Dustin
392" G3 Hemi
1.37, 6.17@111, 9.74@136.9
#2396350 - 10/31/17 09:12 PM Re: First outing with junkyard 5.7 = Win!! [Re: 71yelladustr]
Thanks Dustin! I've been following your build as well. I'm wanting to replace the 440 in my Duster with something similar to your setup. I want something that is low maintenance and hauls the mail naturally aspirated. Your car is very impressive!
10.02@134
#2396379 - 10/31/17 09:48 PM Re: First outing with junkyard 5.7 = Win!! [Re: 71yelladustr]
cudaman1969 Offline
Loc: fredericksburg,va
What pistons to get over 10 comp
#2396502 - 11/01/17 06:32 AM Re: First outing with junkyard 5.7 = Win!! [Re: cudaman1969]
ric3xrt Offline
The stock Pre 09 pistons yield monster compression with the Eagle heads
Did you open up the top ring Gap at all?
#2396522 - 11/01/17 08:02 AM Re: First outing with junkyard 5.7 = Win!! [Re: 71yelladustr]
Didn't touch the rings
10.02@134
#2396526 - 11/01/17 08:08 AM Re: First outing with junkyard 5.7 = Win!! [Re: 71yelladustr]
cudaman1969 Offline
Refresh my memory, what years for Eagle heads? I guess I'll be looking for a set.
Edited by cudaman1969 (11/01/17 08:09 AM)
#2396553 - 11/01/17 08:55 AM Re: First outing with junkyard 5.7 = Win!! [Re: cudaman1969]
sixpackgut Offline
Loc: Charleston
09 and newer 5.7 heads
#2396632 - 11/01/17 11:21 AM Re: First outing with junkyard 5.7 = Win!! [Re: 71yelladustr]
moparmitch Offline
Loc: MI, USA
How much cam lift at the valves and what kind of clearance to piston.
This is a shelf cam?
#2396679 - 11/01/17 12:24 PM Re: First outing with junkyard 5.7 = Win!! [Re: moparmitch]
Comp 112-502-11 cam. Known as 273 xfi cam. .550/.547 lift. Clearance is tight. Not much room for anything bigger without intake valve notches on the pistons. Tried a 229/235 Drag pack cam but would not clear factory 08 and down pistons. Intake valves were contacting pistons.
10.02@134
Page 1 of 3 1 2 3 >
25,743 Registered Members
193,025 Topics
Airtemp Infringing
by scatcity
02/22/19 11:32 AM
413 valve size
by als499
02/22/19 11:30 AM
Who sells A-Body Rear Leaf Spring Rebuild Kits?
by vinnyd76
02/22/19 09:58 AM
Rich Edelebrocks
by moparjack44
02/22/19 09:37 AM
