Cut the oil filter open #2363467
09/01/17 01:43 PM
09/01/17 01:43 PM
northwest USA
N
NANKET Offline OP
NANKET  Offline OP
N
northwest USA
How and what do you use to cut the oil filter open and keep the shavings from cutting from getting all over the inside of filer and spoiling your search for particles?
Re: Cut the oil filter open [Re: NANKET] #2363474
09/01/17 01:58 PM
09/01/17 01:58 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
I bet a chain type exhaust cutter would work.
Re: Cut the oil filter open [Re: NANKET] #2363475
09/01/17 01:58 PM
09/01/17 01:58 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Summit sells a bunch of them. They look kind of like glass cutters. Just put "oil filter cutter" into their search engine. Particles are normal, chunks? Maybe not so normal.
Re: Cut the oil filter open [Re: NANKET] #2363491
09/01/17 02:20 PM
09/01/17 02:20 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Use a large pipe/tubing cutter
Re: Cut the oil filter open [Re: DAYCLONA] #2363494
09/01/17 02:26 PM
09/01/17 02:26 PM
iagree scope
A sharp knife to cut the paper all the way around on both ends so you can remove it from the canister center and look inside the pleats helps also sawzall
Re: Cut the oil filter open [Re: NANKET] #2363495
09/01/17 02:27 PM
09/01/17 02:27 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Drill a hole and use a pair of tin snipes since most people don't that big of a pipe cutter.
Re: Cut the oil filter open [Re: Challenger 1] #2363515
09/01/17 03:11 PM
09/01/17 03:11 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I have an actual oil filter cutter like pictured. Makes it much easier. Not that any of the other ways mentioned are difficult and still work just fine.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Cut the oil filter open [Re: 6PKRTSE] #2363614
09/01/17 05:17 PM
09/01/17 05:17 PM
Lakeland FL
floridian Offline
floridian  Offline
Lakeland FL
That is cool.. I had no idea there was such a thing....
Re: Cut the oil filter open [Re: floridian] #2363651
09/01/17 06:15 PM
09/01/17 06:15 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Go to the airport and ask a A&P mechanic to show you one, or to cut yours open. You can get one from Aircraft Spruce and speciality Co.
Re: Cut the oil filter open [Re: NANKET] #2363673
09/01/17 06:59 PM
09/01/17 06:59 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
Made this myself.
Re: Cut the oil filter open [Re: John_Kunkel] #2363693
09/01/17 07:51 PM
09/01/17 07:51 PM
Cincinnati, Ohio
Cincinnati, Ohio
Nice job! up
Re: Cut the oil filter open [Re: NANKET] #2363696
09/01/17 07:55 PM
09/01/17 07:55 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Looks a little flimsy to me John...LOL
Joe
Re: Cut the oil filter open [Re: NANKET] #2363707
09/01/17 08:19 PM
09/01/17 08:19 PM
BDW Offline
BDW  Offline
Someone has too much time........
Just how many filters you cutting open?
J/K, very impressive
Re: Cut the oil filter open [Re: BDW] #2363900
09/02/17 03:39 AM
09/02/17 03:39 AM
Rio Linda, CA
Rio Linda, CA
With aircraft it's common practice to cut the filter open at each oil change.
Re: Cut the oil filter open [Re: NANKET] #2364021
09/02/17 01:05 PM
09/02/17 01:05 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Re: Cut the oil filter open [Re: John_Kunkel] #2364077
09/02/17 02:45 PM
09/02/17 02:45 PM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
i have a co-worker who owns and flies.
i think he says they must cut filters open after every oil change.
he says he puts the filter in a vice and uses a sharp chisel to cut them open.
perception is 90% of reality
Re: Cut the oil filter open [Re: BDW] #2364085
09/02/17 03:01 PM
09/02/17 03:01 PM
I cut every filter open every time and inspect the contents up
Knowledge is power up work
Re: Cut the oil filter open [Re: 451Mopar] #2364088
09/02/17 03:01 PM
09/02/17 03:01 PM
That's the one I have and use, works good up
