Re: Cut the oil filter open
[Re: NANKET]
#2363491
09/01/17 02:20 PM
09/01/17 02:20 PM
Posts: 18,157 Mass
DAYCLONA
Mass
How and what do you use to cut the oil filter open and keep the shavings from cutting from getting all over the inside of filer and spoiling your search for particles? Use a large pipe/tubing cutter
[Re: DAYCLONA]
#2363494
09/01/17 02:26 PM
09/01/17 02:26 PM
Posts: 43,200 Bend,OR USA
Cab_Burge
How and what do you use to cut the oil filter open and keep the shavings from cutting from getting all over the inside of filer and spoiling your search for particles? Use a large pipe/tubing cutter A sharp knife to cut the paper all the way around on both ends so you can remove it from the canister center and look inside the pleats helps also
[Re: Challenger 1]
#2363515
09/01/17 03:11 PM
09/01/17 03:11 PM
Posts: 4,566 Motor City
6PKRTSE
Motor City
I have an actual oil filter cutter like pictured. Makes it much easier. Not that any of the other ways mentioned are difficult and still work just fine.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#2363614
09/01/17 05:17 PM
09/01/17 05:17 PM
Posts: 1,574 Lakeland FL
floridian
Lakeland FL
I have an actual oil filter cutter like pictured. Makes it much easier. Not that any of the other ways mentioned are difficult and still work just fine. That is cool.. I had no idea there was such a thing....
[Re: NANKET]
#2363696
09/01/17 07:55 PM
09/01/17 07:55 PM
Posts: 1,317 Ohio
jlatessa
Ohio
Looks a little flimsy to me John...LOL
Joe
[Re: BDW]
#2363900
09/02/17 03:39 AM
09/02/17 03:39 AM
Posts: 25,821 Rio Linda, CA
John_Kunkel
Rio Linda, CA
With aircraft it's common practice to cut the filter open at each oil change.
[Re: John_Kunkel]
#2364077
09/02/17 02:45 PM
09/02/17 02:45 PM
Posts: 4,922 new berlin wisconsin
Mr T2U
i have a co-worker who owns and flies. i think he says they must cut filters open after every oil change. he says he puts the filter in a vice and uses a sharp chisel to cut them open.
perception is 90% of reality
[Re: BDW]
#2364085
09/02/17 03:01 PM
09/02/17 03:01 PM
Cab_Burge
Someone has too much time........ Just how many filters you cutting open?
J/K, very impressive I cut every filter open every time and inspect the contents Knowledge is power
