73 Duster 340 AC & Power steering questions #2352915
08/12/17 05:48 PM
08/12/17 05:48 PM
Mass
Mike Mancini Offline OP
Mass
Does anyone have pics of the engine pulley and belt arrangement on an original 73 Duster w/ AC & PS?
Michael L. Mancini
American Muscle Car Restorations, Inc.
65 Foliage Drive
N. Kingstown, RI
Premium Quality Restoration Services for Hi-Performance & Classic Automobiles. OE Specialists.
Instrument Specialties, Inc
www.instrument-specialties.com
www.manciniresto.com
www.performancecargraphics.com
Re: 73 Duster 340 AC & Power steering questions [Re: Mike Mancini] #2352970
08/12/17 08:44 PM
08/12/17 08:44 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I posted pics of a survivor 73 340 a/c duster. But I think the pictures are gone from
Moparts:(
Links:
https://board.moparts.org/ubbthreads/ubbt...60-1972-up.html
https://board.moparts.org/ubbthreads/ubbt...e-survivor.html
Re: 73 Duster 340 AC & Power steering questions [Re: Mike Mancini] #2353016
08/12/17 10:52 PM
08/12/17 10:52 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Pics
MoparsInMay13Sm051.JPGMoparsInMay13Sm046.JPGMoparsInMay13Sm038.JPGMoparsInMay13Sm054.JPG
Re: 73 Duster 340 AC & Power steering questions [Re: Mike Mancini] #2353384
08/13/17 11:22 PM
08/13/17 11:22 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
That is how the belts/pulleys look on my 70 Sport Satellite, 318 with AC . . . two belts for the alternator and AC compressor. One belt for the water pump, fan and power steering pump.
Re: 73 Duster 340 AC & Power steering questions [Re: Mike Mancini] #2353523
08/14/17 10:55 AM
08/14/17 10:55 AM
Mass
Mass
Is there an idler pulley in the configuration?
The car in the shop has an idler pulley as well.
Someone had monkey'd with the ps pump and the books have no good detail on this set up.
Michael L. Mancini
65 Foliage Drive
N. Kingstown, RI
Re: 73 Duster 340 AC & Power steering questions [Re: Mike Mancini] #2353562
08/14/17 12:33 PM
08/14/17 12:33 PM
a12rag Offline
a12rag  Offline
Pretty sure it would be like my 70, with no idler . . .just the belt on power steering pump going round the ps pump and the water pump and the crankshaft.
Here is pic putting engine into car, just did not have the fan and pulley on water pump . . . that is all there is for the ps pump and water pump. This pic shows missing triangular shaped bracket that goes behind front bracket of power steering pump. Should be behind the bracket with adjustment slot - finally figured that out !!! Doesn't matter if saginaw or federal ps pump . . . still need the small triangular bracket that mounts to water pump and adds support for the slotted adjustment bracket . . .
Cheers
Re: 73 Duster 340 AC & Power steering questions [Re: Mike Mancini] #2353673
08/14/17 03:47 PM
08/14/17 03:47 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
No idler.
I have 20-30 detail pics of this car in higher quality. The pics I posted are the only one of the pulleys. Email me direct at info@cpwclub.com if you need other pics.
