Page 2 of 6 1 2 3 4 5 6
Re: Totally Anal Small Block Details- 318/340/360 1972 & Up [Re: ScottSmith_Harms] #1619051
05/12/14 01:00 PM
05/12/14 01:00 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I've seen that one on person. Have any pics of the engine mounts on any of them?
No, sorry. Closest thing is part of the drivers side motor mount thru bolt in the "drivers front" picture.
Re: Totally Anal Small Block Details- 318/340/360 1972 & Up [Re: autoxcuda] #1619052
05/12/14 04:39 PM
05/12/14 04:39 PM
Connecticut
1972CudaV21 Offline
1972CudaV21  Offline
Connecticut
Wow, I can get in on this post...lol
Re: Totally Anal Small Block Details- 318/340/360 1972 & Up [Re: 1972CudaV21] #1619053
05/12/14 05:36 PM
05/12/14 05:36 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Wish I had some 72 pictures.
But there are pics of that survivor black 72 340 Duster that Dmoore owned in the Member Projects & Survivor Pictures section I believe.
Re: Totally Anal Small Block Details- 318/340/360 1972 & Up [Re: autoxcuda] #1619054
05/18/14 05:54 PM
05/18/14 05:54 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
btw, car....
BTW I am at a car show with this car right now. Anyone want specific pictures??
Re: Totally Anal Small Block Details- 318/340/360 1972 & Up [Re: autoxcuda] #1619055
05/21/14 11:53 PM
05/21/14 11:53 PM
PA
P
PLATINUM6BBL Offline
P
PA
Ill have to see if I still have the pics of when I pulled the 360 out of my challenger.
1969-1/2 A12 LOH Road Runner A4 w/ M6S
13.34 at 104 PSMCDR 9/06 in Mopar Action 8/07
12.95 at 105.94 F.A.S.T. 11/06
Re: Totally Anal Small Block Details- 318/340/360 1972 & Up [Re: PLATINUM6BBL] #1619056
05/22/14 02:24 AM
05/22/14 02:24 AM
Kennewick, Wa.
71vert340 Offline
71vert340  Offline
Kennewick, Wa.
Where is the fuel filter located on an untouched original small block?
Re: Totally Anal Small Block Details- 318/340/360 1972 & Up [Re: 71vert340] #1619057
05/22/14 02:28 AM
05/22/14 02:28 AM
Kennewick, Wa.
71vert340 Offline
71vert340  Offline
Kennewick, Wa.
It looks like it's located under the alternator. If so, is there a threaded nipple out of the fuel pump or does the metal fuel line come out of the fuel pump and then the fuel filter is inserted in the cut line using 2 short pieces of fuel hose?
Terry
Re: Totally Anal Small Block Details- 318/340/360 1972 & Up [Re: 71vert340] #1619058
05/22/14 02:30 AM
05/22/14 02:30 AM
Spokane Washington
ScottSmith_Harms Offline OP
Mr Wizzard
Mr Wizzard
Spokane Washington
Right on top on the passenger side front. Steel line threads into the fuel pump, runs up behind the alternator to a short rubber hose, to the filter, to another short rubber hose, then to another steel line that threads into the carburetor fuel inlet fitting. This is a 71 340, other small block locations may vary some but all will be similar.
Re: Totally Anal Small Block Details- 318/340/360 1972 & Up [Re: ScottSmith_Harms] #1619059
05/22/14 10:06 AM
05/22/14 10:06 AM
Kennewick, Wa.
71vert340 Offline
71vert340  Offline
Kennewick, Wa.
My 1971 Challenger 340 has the fuel filter in the same place as Scott shows in his picture. My 74 Charger 360 has the fuel filter located below the alternator as shown in the 5th picture down of the evap sys., washer bottle and alternator on the 73 Duster 340. I just didn't know if this was the correct location on my 360. I just received a reproduction fuel line for my 74 that is one piece from the fuel pump to the Thermo-quad and has the threaded fittings on both ends. I'm trying to figure out where to cut it. Thanks .
Terry
Re: Totally Anal Small Block Details- 318/340/360 1972 & Up [Re: 71vert340] #1619060
05/22/14 10:25 AM
05/22/14 10:25 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
......Which is the reason I posted this thread, correct detail info on other year 318/340/360 small blocks are difficult to find
Re: Totally Anal Small Block Details- 318/340/360 1972 & Up [Re: ScottSmith_Harms] #1619061
05/22/14 10:51 AM
05/22/14 10:51 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
The later engines have the fuel filter under the alt. There is a "U" shaped line that comes out of the fuel pump...then the filter...then the line that goes up to the carb.
Fine Lines didn't list a pump to carb line for my 73. I sent them my original lines and they bent me a perfect set.
Re: Totally Anal Small Block Details- 318/340/360 1972 & Up [Re: burdar] #1619062
05/22/14 11:01 AM
05/22/14 11:01 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Here is the fan off of my 73 318. September 72 SPD but built on Oct 12th.
The fan was repainted in the 90's but I couldn't get the spacer off. When I was redoing things a couple years ago, the spacer needed to be removed. It ended up cracking it was on there so tight. You can see what's left of the "ENGINE SIDE" stamp as well as some orange paint or possibly adhesive on the spacer and fan.
Re: Totally Anal Small Block Details- 318/340/360 1972 & Up [Re: burdar] #1619063
05/22/14 11:05 AM
05/22/14 11:05 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Original coil for 73 318(Challenger) Soaked in EvapoRust to reveal the stampings.
There is a three digit date code on the opposite side. I don't think I have a picture of that.
Re: Totally Anal Small Block Details- 318/340/360 1972 & Up [Re: burdar] #1619064
05/22/14 11:09 AM
05/22/14 11:09 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Original choke thermostat. This is the only one I've seen this way. There were 2 bolts that attached this to the intake. All the others I've seen have only used one bolt with a tab on the other end.
Re: Totally Anal Small Block Details- 318/340/360 1972 & Up [Re: burdar] #1619065
05/22/14 11:12 AM
05/22/14 11:12 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
What I believe to be the original booster to intake hose.
Re: Totally Anal Small Block Details- 318/340/360 1972 & Up [Re: burdar] #1619066
05/22/14 11:29 AM
05/22/14 11:29 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
These next two are off of a 73 Cuda 340 that was built a week after my Challenger in Oct 72. These were taken when the car was only a few months old. The car is still owned by the original owner and only has 36,000 miles on it.
The original carb never acted right. It was replaced very early on.(along with the air cleaner) The rest is supposed to be original.
What I notice is...
gray throttle return spring
light green kickdown spring
unpainted heater hose fitting
BLACK PLUG WIRES (owner says this is what the car came with)
black dipstick handle
not really an engine detail but the master cylinder cover is not zinc dichromate plated...it looks phosphated
no fuel filter on top of the intake
a piece of insulation around one of the heater hoses
Re: Totally Anal Small Block Details- 318/340/360 1972 & Up [Re: burdar] #1619067
05/22/14 11:37 AM
05/22/14 11:37 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I believe this pic was sent to my by Mike Mancini. It's of a 73 318 and he circled the painted rubber valve cover gasket. I also see paint marks on the EGR valve hoses. Yellow stripe on the short hose from carb to "T". Then white from the "T" to the EGR valve. It looks like light blue on the line that goes from the "T" to the valve on the firewall but the FSM shows it being green.
The plug wires are black on this engine too. I have no idea if they were replaced or if they are supposed to be original.
Re: Totally Anal Small Block Details- 318/340/360 1972 & Up [Re: ScottSmith_Harms] #1619068
05/22/14 02:15 PM
05/22/14 02:15 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Dang I could have taken a detail picture of the fuel filter on the 73 340 Duster on Sunday when I saw it at a show.
Re: Totally Anal Small Block Details- 318/340/360 1972 & Up [Re: autoxcuda] #1619069
05/22/14 02:18 PM
05/22/14 02:18 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
The harder to see details, things you'd see with the air cleaner removed and from angles other than the typical few feet away hood open/car show angles are what's really needed.
Re: Totally Anal Small Block Details- 318/340/360 1972 & Up [Re: ScottSmith_Harms] #1619070
05/22/14 03:47 PM
05/22/14 03:47 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
Close up details of assembly, individual parts, part number fonts, factory stampings, assembly bolt styles and types, hose and wire routing, etc, etc is what Scott is after.
MLR426
