Re: in tank fuel pump Fitech Efi
[Re: dickdale]
#2323906
06/19/17 11:32 PM
06/19/17 11:32 PM
Posts: 10,498 Chicago, Illinois
Devil
Chicago, Illinois
I just pulled my tank out again.
I have a Walbro Electric pump in the tank. It is a GSS342 pump that produces 255 lph.
Two other friends got basically the same tank, one for a 70 Challenger and another for a 72 'Cuda and they both had the same pump.
So I do not know where the other info came from.
[Re: dickdale]
#2325799
06/23/17 04:21 PM
06/23/17 04:21 PM
Posts: 1,822 Colorado
denfireguy
Colorado
On my Ebody, I have had the Tanks and the Spectra EFI tanks. Spectra all the way. Which EFI did you use? Using a Megasquirt 2 controlling a Holley Terminator throttle body. Was also using a PWM controller for the Walbro pump but found out Walbro does not recommend using pump controllers. I am back using a mechanical regulator. It is pretty well dialed in with the exception of IAC and secondary injector tip in. Enjoying the car now, this stuff will be adjusted later. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
